need help with dd install
to those who installed the DD A/C unit... do they only come in black? I have the silver buttons... is my next and only option to remove each and every single button 1 by 1?
This is a pain in the A$$ so far and all i did was remove the dead button and i'm still trying to remove the other ones.
Mine is an '04 aero sedan with the silver/alum trim = black buttons.
Didn't know about the willow with silver buttons.
Did you e-mail yoshi?
yosi@j-garage.com
yosi@j-garage.com
Really? Less than a week for something that's coming from overseas? That's a real quick turn around.
~Julie~
~Julie~
Yes , your only option is to switch every button. Be advised, the are very soft switches. If you press on them to hard they will break. So be very careful. I have an '03 and did the DD conversion and did not liked the way the A/C buttons looked. Good luck!
i just found a better solution... Instead of changing over every single button, i'm just having my friends car warrantied saying his dual climate control button doesnt work, and instead of grey i'll just change over to black button's using my friends new black dual climate control button. since none of the other buttons for the radio, sat, am/fm and tape will be there.
