reuse factory amp?
Old Sep 11, 2005 | 06:00 PM
mephistomyhero's Avatar
Originally Posted by civic5zigen
What adapter, can't I just tap into the Bose input as bare wire?
Yes you can but I don't know what the output of the soundcard vs the input of the BLOSE is. That is why you may need the adapter to match the impedence. What impedence matching does is exactly that, it matches the output of the soundcard to the inputs on the BLOSE amp. If the output of the soundcard is really low, you will have to turn up the soundcard settings and that will induce alot of HISSING noise and even alternator whines. You get this alot with high-level (speaker level) output/input due to the various speaker setting. I just don't know what the output vs the input settings you are going to use so that will depend on that. Good luck.
Old Sep 12, 2005 | 12:39 AM
civic5zigen's Avatar
how much does such adapter cost? How much am I looking at for a average 4 or 5ch amp?
Old Sep 12, 2005 | 10:09 AM
amthar's Avatar
Average 5 channel amps are going to run you $400+, closer to $500 retail. But they also go up to as high as $1000 & $1300. Check ebay.
An average 4 Channel amp will run about $200~$250. Of course you can get them as cheap as $100 and as expensive as $700. Check ebay.
Old Sep 12, 2005 | 07:22 PM
That's why I want to reuse the bose amp. So what is the adapter I need to buy? Can someone offer some help?
Old Sep 12, 2005 | 07:44 PM
el_duderino's Avatar
If you want to use a single-ended output into a Bose amp, try the Peripheral SVEN4 or the Soundgate XR4.
https://www.soundgate.com//index.php...&usereferrer=1
http://www.discountcarstereo.com/detail.aspx?ID=753
Old Jan 30, 2010 | 03:01 AM
TwilightSedan's Avatar
you need a wiring harness. i'm doing the same thing, i'm giving the existing bose system a shot with an aftermarket head unit to see if i can salvage it. You need the metra 70-7551 harness to use the bose system. It has rca plugs and connects to the pre outs of your head unit. Get one with three pre outs at 4 or 5 volts each. One for your fronts, one for your backs and one if you want to add an extra set of subs. The bose amp needs strong voltage pre outs to reduce risk of very low sound. If you plan on bypassing and tearing out your stock bose amps without testing them out, you would use the 70-7550 model harness. In that event you would also need to run new wires to your speakers and may lose the function of your fifth interior speaker/subwoofer. Never ever cut into your cars wiring. The RCA inputs are incorporated into your vehicles harness. You need to buy the harness adapter. look up the metra 70-7551 and you'll see from the picture what i'm talking about. The harness goes for about 20 bucks everywhere, i got it from here, http://www.cartoys.com/Default.cfm/p...:referralID=NA for 9 dollars with free shipping. And by the way, when people on here say that your head unit outputs don't match your bose system inputs, what they mean is your head unit produces an unbalanced signal while the bose amp is configured to accept a balanced signal. This is some cases causes distortion depending on your head unit. From what i've read, there is something that's called a balance transmitter or something of that nature that can deal with this problem as well if it occurs. I'm about to be testing all this out first hand soon.
Old Jan 30, 2010 | 05:25 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Zombie thread!
It's been buried over 4 years man, let it go!
Old Jan 30, 2010 | 05:59 PM
mattyjman's Avatar
wow...don't quite know what to say about this! Good tip TWILIGHTSEDAN but i am most sure that he either figured it out 4 years ago, or has a new car by now
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
TurTLe*
Sep 29, 2015 01:43 PM
