2-ohm speakers
Old Sep 12, 2005 | 06:03 PM
D87's Avatar
D87
2-ohm speakers
Are there any 2-ohm speakers on the market to do a direct replacement for the stock ones in the G?
Old Sep 12, 2005 | 07:00 PM
khsonic03's Avatar
Image Dynamics
http://miata.cardomain.com/item/IDSCXS62
Old Sep 12, 2005 | 07:13 PM
cfulback32's Avatar
I've been looking at those. They seem to get pretty good reviews. Not sure if by "direct replacement" you meant that you'd keep the stock bose amp and just change the speakers, but those Image Dynamics have a RMS rating of 150 watts. You'd definitely need an aftermarket amp.
Old Sep 12, 2005 | 07:23 PM
D87's Avatar
D87
I wonder if there are any amps that can fit in the same slot as the stock one. I don't have to have to do any drilling or extra mounting.
Old Sep 12, 2005 | 08:23 PM
khsonic03's Avatar
Ummm...no. The only way I'd recommend those speakers is if you are planning on upgrading the amp eventually. They are a good base to start with. You will not find a amp that will "replace" the factory amp...you will have to do a little more than that. Image Dynamics makes GREAT speakers.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MrIP35
Oct 25, 2015 11:13 PM
1Typhoon
Sep 25, 2015 08:45 PM
JustinMKN1
Sep 18, 2015 03:40 PM
Mikesta
Sep 10, 2015 05:14 PM
