SUBS & AMP
Old Oct 13, 2005 | 01:29 PM
SkylineG35x's Avatar
SUBS & AMP
I am getting ready to install a new SUBS/AMPS in the trunk and still keep my Factory AMPS for the bose speaker. Should I get one of these PAC AOEM-NIS2 ? or use a LOC better ?
Old Oct 13, 2005 | 02:28 PM
amthar's Avatar
The PAC AOEM NIS2 requires you to take apart your dash to connect it and then run RCA cables to your trunk. A LOC can be tapped into the wires in your trunk.
If taking apart the dash and running the RCAs does not bother you (you're going to have to run a power wire for the aftermarket amp anyways) then it's pretty much a toss up if your amp takes balanced inputs. If it does not take balanced inputs, get a loc that also serves as a balance-to-single-ended adapter.
Old Oct 13, 2005 | 06:31 PM
Thanks again, Amthar saves the day!!!
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
