XM Roady XT Installed. *PICS*
Old Oct 15, 2005 | 12:04 PM
cup0spam's Avatar
OK so I installed the XM Roady XT yesturday. Used the 2nd input on my pac-audio input adapter. The install went pretty smoothly, i used a dremel to pass the wires into the nav compartment. Also, instead of ruining the exterior of the car, I mounted the antenna in the front windshield. I drove around like this for a while and there apperared to be no negatives associated with this placement.
Pic 1
Pic 2
Pic 3
Pic 4
Old Oct 15, 2005 | 03:32 PM
SCoupe's Avatar
Originally Posted by cup0spam
OK so I installed the XM Roady XT .... Also, instead of ruining the exterior of the car, I mounted the antenna in the front windshield.
Looks good. Xact setup I've been thinking.
If you have time, would you mind posting an update on reception with antenna in that location ?
Old Oct 15, 2005 | 07:49 PM
cup0spam's Avatar
Reception hasn't been an issue at all. I dont know why people think they need to have them outside their car. Perhaps in an area with a lot of mountain terrain and no FM repeaters it may not work as well as it would if it was outside the car, but I've had nothing but success mounting it in that spot.
Old Oct 15, 2005 | 07:59 PM
WhosUrBuddiee's Avatar
Why didnt your car come with XM?
Old Oct 15, 2005 | 08:12 PM
cup0spam's Avatar
My car came wired for XM, but there are several reasons why I didn't choose the factory installed option.
1) The price of my install was $99 (the price of the unit)
2) Found a promotion code (XMSCION03) that gives me 3 months free, and no activation charges (didn't even have to give XM my credit card number, it'll just turn off in 3 months)
3) I didn't want an antenna on my roof
4) The stock HU display sucks for XM textual content
5) I can bring the unit into my house or anywhere I want to listen to XM
...I could keep going but I think you get my point.
Old Oct 16, 2005 | 12:28 AM
G35_TX's Avatar
Can you give some more detail on how you installed it to your stock headunit as I have the older Roady and would like to reinstall it on this car as well.
Old Oct 16, 2005 | 10:29 PM
cup0spam's Avatar
I used the Pac-Audio input adapter to get the aux in...
Old Oct 16, 2005 | 11:36 PM
G35_TX's Avatar
That isn't details on how you installed it.
Old Oct 16, 2005 | 11:48 PM
truplay8's Avatar
THE BATMOBILE
stealth..........i like it
Old Oct 16, 2005 | 11:51 PM
cup0spam's Avatar
OK. Install info as requested:
The first leg of my install was to install the Pac-Audio AAI-NIS behind the HU. I had to unplug the pre-wired sat cable (that runs to the trunk where the OEM reciever would be) and plug the AAI-NIS in it's place. I made a splice off the 12v wire behind the cigarette lighter for the belkin ipod auto cable, which allows me to have audio and power coming into my iPod over one cable. Once the AAI-NIS was in place, cycling through the radio button (or mode button on the steering wheel) would show SR-1 / SR-2 following FM2. SR-1 being aux-1 and SR-2 being aux-2. After the audio stuff was done I went ahead and made a second splice, hardwiring my radar detector while everything was already taken apart.
This weekend I did the Roady XT. I removed the panels again, cut a hole in the side of the NAV cubby with a dremel, and ran power,audio,antenna through. I chose the side of the cubby because small objects would get lost if I had done it on the bottom. Anyway, I ran my audio to the pac-audio's 2nd input, and bought a wired cigarette lighter adapter, and a splitter, so I didnt have to break apart the cigarette lighter power cable for the XM unit...
As far as mounting goes, I have some high strength 3M double sided tape holding the unit onto the back of the cubby door. When you close the door the unit simply flips upside down and hides inside perfectly. I've been thinking about switching to some industrial strength velcro instead though, so if I feel like bringing the unit inside my house to listen to it wont be a pain in the ***.
Hope this helps, if you need a specific question answered just let me know, I'll be happy to help.
Old Oct 17, 2005 | 07:34 AM
Beowulf's Avatar
FYI you also get the 3 month free promotion from XM or Sirius if you tell them you are activating a nissan installed sat radio. Our stupid OEM radios are overpriced.
I have have my factory antenna on my rear deck on a small metal plate and it works perfectly.
Old Oct 17, 2005 | 10:15 AM
amthar's Avatar
da** you, now I have ANOTHER project.
Old Oct 27, 2005 | 05:33 PM
MADDD_G's Avatar
hi, where can I buy the Pac-Audio AAI-NIS adapter? Thanks!
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
R350k5
Oct 1, 2015 08:41 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
