Amp Preinstall help/advice
Old Oct 18, 2005 | 09:39 PM
etang789's Avatar
I finally made the decision to get a JL 300/4 (purchased from Ebay). To power my front MB Quart PCE 216 which i had installed about a year ago, and recently with just the front speaker upgrade is not enough for me. And I also bought the 8 guage amp kit from KnuKoncept.com
Ok here is the problem:
I have read many post about wiring the amp but still not clear, i have decided to get rid of the blose amp completely. Which means im tapping the signal before bose amp. And doing this Im thinking to just use speaker wire to RCA to connect to the 300/4. but i have problem finding the right wire to do so...I have found this http://www.radioshack.com/product.as...5Fid=42%2D2370. Is this the right one that i should use? or there are better option? or should I go with soundgate LOC4.4?
Advice needed:
Should I go with upgraded 6x9 or a sub? And these would also power by the 300/4. Im on a tight budget here.
If a sub im thinking about 10w1v2d4? and do i get 2ohm or 4ohm?no clue here...
At the end im aiming for SQ, I listen to mostly vocal stuff, pop, chillout music, jazz, some hiphop.
Please help out guys...
Old Oct 18, 2005 | 10:16 PM
SkylineG35x's Avatar
1. http://www.radioshack.com/product.as...5Fid=42%2D2370. Is this the right one that i should use? or there are better option? or should I go with soundgate LOC4.4?
I would go with the soundgate LOC.
2. Should I go with upgraded 6x9 or a sub?
This depends, if you dont care about trunk space then go with a sub.
3. If a sub im thinking about 10w1v2d4? and do i get 2ohm or 4ohm?no clue here.
Well, I have no clue here either.
4. At the end im aiming for SQ, I listen to mostly vocal stuff, pop, chillout music, jazz, some hiphop.
Don't we all want SQ. since you are on a budget, do what I did, change the front speaker and add a Amp/sub, and leave the 6x9 alone.
Old Oct 19, 2005 | 12:14 AM
el_duderino's Avatar
LOL.
1) You don't need an LOC. Ask amthar. What you need is an RCA that you're not afraid to cut in hal - preferably twice as long as the distance from your amp to your Bose amp (so you can use both halves) and preferably twisted pair.
2) Sub will sound better.
3) If you are running a 300/4, and 1/2 of that would run your sub, it doesn't matter. The 300/4 puts out the same power into 2 or 4 ohms. So the amp doesn't care. I'd get a SVC 4 if you can.
4) No, you don't ALL want SQ (but a lot of you sure say you do).
You will notice that with an amp the vocals thru the MBQs will get a bit strained and maybe fatiguing to listen to after a little while.
Then you'll probably upgrade those...
Old Oct 19, 2005 | 01:55 AM
etang789's Avatar
Originally Posted by el_duderino
LOL.
Where can i find some cheaper price twisted pair? radioshack?
what is a SVC? Single Voice Coil? is JL 10w1v2 SVC? coz im thinking of that. any other sub to suggest in the price range
what do u mean by strained and fatiguing?
Old Oct 19, 2005 | 08:56 AM
amthar's Avatar
Single Voice Coil.
The 10w1v2 is an SVC subwoofer. They make a 4 ohm version (what you would need) and an 8 ohm version (what you would NOT need).
All JL subs that are DVC have a "D" in their model # or otherwise denote they are "DVC" or "dual voice coil" on their spec page(s). Example: 10w3v2d4 is a 10w3v2 in a dual 4 ohm voice coil configuration.
Dual voice coil amps provide you with more wiring configurations (to obtain different resistance/load rating), but as you have a JL "slash" series amp with a variable/regulated power supply, this is not as much of a benefit as with standard non-regulated amps (as your amp produces the same amount of wattage/output at any resistance between [including] 1.5ohms and 4 ohms).
SVC subs are much more straight forward in the "connect and go" sense.
Old Oct 20, 2005 | 08:38 AM
etang789's Avatar
Ok here is what i will get later today...
JL 10w1v2 4ohm
4080 box
Metra 70-7551 amp adaptor (so i dont have to cut up the stock wiring and my new rcas)
any suggestions in how to bolt the amp down, and where is the best grounding spot. is it ok to drill the metal floor where the bose amp is now, to mount the new amp?
Old Oct 20, 2005 | 09:13 AM
amthar's Avatar
Industrial strength velcro! You think I'm kidding but I see no reason not to do it. Couple big strips on the floor of the trunk where the stock amp used to be.... get the industrial strength stuff. It won't be going anywhere.
Old Oct 20, 2005 | 10:51 AM
Unless you're in an accident... then it has a nasty head of dark velocity, as Neal Stephenson once said.
Old Oct 22, 2005 | 02:39 AM
etang789's Avatar
Ok I have a next problem to solve... i need to buy a sub. I cannot decide what to get, since i dont want to spend so much now. Im looking at
JL 10W1v2-d4 or the Elemental Design 11Kv.2
Old Oct 25, 2005 | 08:49 AM
amthar's Avatar
If you're in an accident that can launch an amp that is velcroed to the floor underneath one of those plastic trunk flooring pieces which is bolted down THROUGH the plastic trunk flooring piece, THROUGH your back seat, take off your headrest or go through the back of your seat, you definately have a bigger problem than an amp hitting you.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
JustinMKN1
Sep 18, 2015 03:40 PM
