Question before installing iPod???
Old Oct 21, 2005 | 07:07 PM
MISTIKMACK's Avatar
Question Question before installing iPod???
I'm about to hardwire my iPod using the PAC AAI-NIS interface but want to know if people ever used this:
http://www.installer-data.com/item/d...m.php?it=pxp01
I want provide power to my iPod when in use but not really feelin the Belkin Car Adapter. With this, I can tap into an existing power supply (cigarette lighter maybe?) and have almost everything hidden. Thanks in advance for any input!
Old Oct 21, 2005 | 07:53 PM
SkylineG35x's Avatar
You dont need it, unless u want to charge ur ipod at the same time. That cable cost 60 bucks. WOW
Old Oct 21, 2005 | 08:07 PM
MISTIKMACK's Avatar
Yeah, I'd like to charge the iPod while in use since my commutes are long. I guess I can go the Belkin route.
Old Oct 21, 2005 | 08:28 PM
el_duderino's Avatar
Here's the kink: If you use a charger that's separate from the audio out, they have different ground potentials (the headphone jack has a ground and the DC in has a ground too, but they are attached to different points in the car.
If you use the piece that you found (which I could get you for $40, but which I don't like much) then you could solve this issue with a ground loop isolator between the cable's RCA and the NISS adapter RCA input.
Or you could get a Dension Icelink AUX with charging, also grabbs the line out, and a preamp in it that eliminates this whole ground loop thing.
But that costs more than $60. It costs like $100 or more, I can't remember...
Old Oct 21, 2005 | 11:24 PM
MISTIKMACK's Avatar
Hmmm...tell me more about this Dension Icelink? Out of curiosity, what don't you like about the wires I found?
My whole idea behind it is to minimize the wires running throughout the car. I just want one simple connection to the iPod that can both play the music and charge at the same time.
RA102223
Aug 15, 2015 09:24 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
BlackGee35
Jul 21, 2015 07:24 PM
