Yet another Valentine 1 install...
Old Oct 26, 2005 | 04:18 AM
RaDaRkInG's Avatar
Originally Posted by Espresso
I'm in MD but often travel in VA/DC where a radar detector is illegal. When in doubt, I hit the kill switch and fold up the ashtray. From the outside, you don't notice anything since my V1 is mounted in the upper passenger corner. The switch is also helpful if you don't really need the detector if in traffic or around shopping malls when it always goes off. Comes in handy with a stealth install where you don't have access to the unit.
Don't worry sbout the V1 in VA/DC, it is the least detectable by a RDD (Radar Detector Detector).
http://www.radardetector.net/viewtop...383&highlight=
Old Oct 26, 2005 | 08:02 AM
Meatshackle's Avatar
Deep Sea Moderator
Originally Posted by MISTIKMACK
But since I don't have that module you're referring to (after reading it up on KPTechnologies' website, it could be an interestng future mod), I guess I have to tap into the thick black/red wire in the ignition.
Just tap into the cig lighter right there. Some people are a little hesitant to tap into ignition wires.
Old Oct 26, 2005 | 03:14 PM
RDaneel's Avatar
Did you run the wire down the A pillar? How did you get it under the dash, is there a way to run it cleanly? Sorry for the questions, I haven't even tried to do my clean V1 install yet...
Old Oct 26, 2005 | 04:33 PM
Espresso's Avatar
Take the A-pillar off and run the wires to the corner of the windshield or if you want, run it all the way to the middle. To get to the center console from the passenger side, I ran the wires behind the glove box but had to take apart the ashtray trim piece to have access to the rest of the install. Use zipties to secure the wires unless you want vibrations. Especially around the A-pillar.
Old Oct 26, 2005 | 06:35 PM
n1cK's Avatar
G35 6MT
good point. that's a very viable solution. i'd go with that if there is nothing else tapped into the ignition wire. it sounds a lot easier.
Old Oct 26, 2005 | 06:36 PM
n1cK's Avatar
G35 6MT
what he said, but i did it on the driver's side. i found it easier (especially since i've taken it apart once or twice before and knew how).
Old Oct 26, 2005 | 09:14 PM
SLVRG35's Avatar
Maybe this will help those needing to tap the ignition wire, but aren't sure how. Pretend the pink wire in the pic is the igntion wire and the other 2 are anything your needing to get power to. Also make sure any power connection you add is properly fused. Hope this helps *Last 2 pics are backwards*
Attached Thumbnails Yet another Valentine 1 install...-wiring12.jpg   Yet another Valentine 1 install...-wiring22.jpg   Yet another Valentine 1 install...-wiring31.jpg   Yet another Valentine 1 install...-wiring44.jpg
Old Oct 27, 2005 | 11:20 AM
Espresso's Avatar
Nice suggestion. If you only need to power 1 thing though, it's easier to use a wire tap and add an inline fuse.
Old Oct 27, 2005 | 11:32 AM
SLVRG35's Avatar
Thats true, but you have to consider who is doing this and what experience they have. If someone were to use an 20-22ga wire tap on an ignition wire, then its very possible the wire will be cut in half. And also if they're not correctly used, can eventually fail.
Old Aug 31, 2009 | 12:58 PM
wongsooiseng's Avatar
The initial picture is broken, can anyone repost??
Where can I get the installation manual for V1 into my rear mirror with the wire? I want to know where to connect which wire (color)
-Sooiseng
Old Sep 1, 2009 | 12:32 PM
Anyone?
help?
-Sooiseng
Old Sep 6, 2009 | 07:06 PM
blAk mAx's Avatar
search for invisicord the go here for install
http://www.myg35mods.com/
Will_blueprint
Jun 28, 2004 09:37 AM
2fast
Apr 7, 2004 06:55 PM
coolie
Mar 18, 2004 04:43 PM
lebushaw
Jun 14, 2003 09:38 PM
