How do you convert wires to RCA?
Old Oct 25, 2005 | 07:41 PM
el_duderino's Avatar
1) that 2-3 minutes is ONLY if you solder well. If you don't solder well, crimp.
2) Ends get loose over time. Even if you don't haar any diff in the moment, don't use ends that will get loose over time if you can help it.
3) Radio Shack ends are for ****e.
Old Oct 26, 2005 | 09:03 AM
waijai's Avatar
i.love.gold
Okay so assuming I do this, I'll have one set of RCA female plugs to use. I am using two amps though, so I would need two sets of RCA's. Would it be best to use two more Y-adapters on my freshly made plugs? Or should I tap/splice into the rear speaker inputs for another set of female plugs?
Tell me if that doesn't make sense.
Old Oct 26, 2005 | 10:48 AM
amthar's Avatar
You would want to use unspliced Y's on your newly attached female RCA pigtails. The fewer taps/splices you make the better.
It would be better if your amp has an RCA preamp passthrough, however, like the JL "slash" series amps and several others. This would prevent you from further decreasing your voltage (which will happen when you "Y" the RCA input going into the amps), which in turn would require you to up your gains, which would cause you to up your noise.
Old Oct 26, 2005 | 11:46 AM
waijai's Avatar
i.love.gold
I guess this is where I could use my line driver
.................................................. ...............--< amp 1
Newly spliced female pigtails --< line driver ---
.................................................. ...............--< amp 2
Old Oct 26, 2005 | 02:24 PM
If your line driver takes balanced inputs.
Old Oct 26, 2005 | 03:15 PM
waijai's Avatar
i.love.gold
I'm checking w/ Phoenix Gold tech support now. I have their PLD1 line driver.
Old Oct 26, 2005 | 04:29 PM
waijai's Avatar
i.love.gold
According to the Phoenix Gold rep:
"The unit is not specifically a “balanced” device but there in no ground reference on the input/output."
So I should be able to use it
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
