Where is the Sat harness on 04 Sedan?
Old Oct 29, 2005 | 06:41 PM
TechFarmer's Avatar
I found the Bose amp under the rear shelf but can't find the sat connector. Where is it? I have an 04 and according the the info I've seen, it should be pre-wired for sat. Thanks!
TechFarmer's Avatar
BTW, this is for a SEDAN, all I could find was coupe info so far after much searching.
Old Oct 29, 2005 | 07:01 PM
akrus's Avatar
The document I have shows it to the bottom right of the pass through in the seatback.
When looking into the trunk from the back of the car, take the trim panel off the underside of the rear parcel shelf (you must have done this if you saw the BOSE), continue removing the trim piece that is covering the back of the seat. The N-bus is shown behind the cross brace that goes under the pass through and angles up to the top right corner of the rear seat.
My car didn't have the N-bus cable, but I have an 05. I've torn half the car apart today in the hunt for red oct.. er, I mean N-bus... Not anywhere near the rear of the car.
I hope this helps.
Albert
Old Oct 29, 2005 | 07:29 PM
TechFarmer's Avatar
Albert,
Thank you very much! I got to the amp and couldn't find the sat connector and got worried. Never guessed it would be in the seat back. Those 4 plastic connectors that fasten the rear seat cover and the parcel cover together are much more difficult to remove than the other fasteners.
Good luck on the hunt for N-bus! Wish I could offer some advice in return.
Old Oct 30, 2005 | 09:00 PM
akrus's Avatar
Glad you found it. I'm ordering the service manual for the car, so the electricals will be in there and then I can spend the 10 minutes looking that the Canadian dealerships refuse to do for me
All in all, I will get XM in the car, just a matter of when...
Albert
Old Oct 31, 2005 | 08:36 AM
TechFarmer's Avatar
I ordered the Infiniti service manuals from http://www.nissan-techinfo.com/infiniti/ . I paid $20 and had 24 hours to download the manuals. It does include a complete wiring diagram but it didn't help me find the physical location of the satellite plug. Good luck!
Old Oct 31, 2005 | 10:24 AM
akrus's Avatar
Whoa!!!! Just checked - they want $295 USD for the 2005 CD.
Albert
Old Oct 31, 2005 | 07:26 PM
TechFarmer's Avatar
Just purchase a one-day subscription for $19.99
Just purchase a one-day subscription for $19.99. Go to the "Available Catalogs" drop-down menu, select "Online Subscriptions", and buy a 1-day subscription for $19.99. You then have to open about 15 PDF files for your vehicle and then save them all to the same directory on your computer. That's what I did anyway.
Old Oct 31, 2005 | 08:22 PM
akrus's Avatar
Online subscription isn't available for the 2005...
I'm gonna have an xm system that rivals the cost of the car before long...
Albert
Hasanbaloch
Feb 29, 2024 08:45 PM
whattf
Sep 1, 2015 07:42 PM
Danielek
Aug 11, 2015 09:33 AM
Mac8008
Aug 4, 2015 09:19 PM
Frostbite91
Aug 2, 2015 04:59 PM
