Questions on installing Subs and amp
Old Nov 6, 2005 | 09:25 PM
crazyg35coupe's Avatar
FGC General Member
Hello i recently purchased a box, subs, and amp for my car.....i am keeping my stock HU and wanted to know how you guys ran your power from your amp pass the firewall and to the battery....if some1 could please help and tell me where and how they put the wires it would be much appreciated....pics might help to lol.....
Thanks
Derek
Old Nov 6, 2005 | 10:03 PM
mrdigital's Avatar
I think a lot fo people are gonna look at this post and either ignore it or tell you to search. There's actually a DIY on here for that...with pics.
Old Nov 6, 2005 | 11:15 PM
amthar's Avatar
I think the DIY pictures are broken. However the text description within the DIY is very good.
Find the rubber grommet above and to the left of the battery (assuming you are starring at the battery from the front of the car). I made a hole in this and ran my power wire throught. It comes out at the passenger side foot area.
Make sure you use silicon to seal around the power wire on the grommet, as this grommet gets soaked by windshield runoff when it's raining.
Then tear our the passenger side interior and run the power wire along there. If you remove the backseat, you'll see a convenient hole (lined with a hard white plasic grommet thing) that allows you to easily get the power wire into your trunk.
Really once you get the power wire through the grommet, if you can blunder your way through removing the interior pieces (not hard if you just pay attention and take your time), it's pretty uncomplicated as far as running the wire.
Old Nov 7, 2005 | 04:32 PM
FGC General Member
thank you very much for the answer.....i did a search and had a hard time finding the exact answer...im glad someone on this forum is kind enough to give me the info and not post some bs answer telling me to search it.....if your gong to take the time to write and answer at least help someone...thanks again....
Old Nov 7, 2005 | 04:57 PM
amthar's Avatar
I didn't give you an answer so you could flame other people. When I needed the DIY myself the pictures were broken too. I used what the DIY said and figured it out myself. So searching for it was still a decent suggestion
Old Nov 7, 2005 | 06:14 PM
mrdigital's Avatar
Thanks, amthar. crazyg35coupe, are you feeling better now that you've vented?
hdmark
Apr 29, 2019 04:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
nervseele
Jul 17, 2015 11:21 PM
