dvd/nav/console/subs/amps modifications
Old Jul 26, 2003 | 07:22 PM
sachb's Avatar
Guys dont know if any one has done this yet, but I just got installed a pioneer dvd in dash w/ screen into my G. Of course with some modifications here and there. Also got the nav to be functionable while driving. Check it out. The guys at a local dealer did an awesome job.
<P ID="edit"><FONT class="small"><EM>Edited by sachb on 07/26/03 05:09 PM.</EM></FONT></P>
Old Jul 26, 2003 | 08:17 PM
sachb's Avatar
Re: dvd/nav/console/subs/amps modifications
some one please tell me how to add pictures i will put them on here
Old Jul 27, 2003 | 01:26 AM
pratG35's Avatar
Check out the FAQ section on how to add links or attachements.
https://g35driver.com/forums/faq_english.php
Old Jul 27, 2003 | 01:02 PM
sachb's Avatar
Re: dvd/nav/console/subs/amps modifications *DELETED*
Post deleted by sachb
Old Jul 27, 2003 | 01:27 PM
sachb's Avatar
ok guys here are pictures.
go to www.clubphoto.com
in the email/friend space type in
sachb79@yahoo.com
type in g35 in the box on the left where it says private album
click on the album
slide show option in the left column
<P ID="edit"><FONT class="small"><EM>Edited by sachb on 07/27/03 10:29 AM.</EM></FONT></P>
Old Jul 27, 2003 | 02:05 PM
paintballbitch's Avatar
Very Cool!!!!!!
I am getting my stereo mod finish on Monday....
Old Jul 27, 2003 | 06:09 PM
G35Lin's Avatar
Multi-Spoked Mod
LOTS of props! Very nicely done! how much was everything??
Old Jul 27, 2003 | 07:01 PM
sachb's Avatar
thanks, it actually didnt cost me too too much bc i had all of the equipment in my old car. only thing i really paid for was the install for the dynamat, pioneer brain and dvd/screen, amp, game plate, nav switcher, the customized console, and the customized box for my speakers. everyhting came to be like 6-700 dollars. ill tell you what though it was much cheaper than going through the nav, because the nav converter itself is 500 + dvd player + install and the quailty of this screen is awesome compared to that of the nav.
Old Jul 28, 2003 | 12:21 AM
lilitalyx's Avatar
Do you happen to know what the shop did to your navigation to get it working while driving?
Old Jul 28, 2003 | 01:12 AM
sachb's Avatar
yes i do. they tapped into the speed sensor wire and basically put a switch onto it. they way it works is the nav is only functionable when the car is not moving so with the switch in the on position tells the brain of the car that the car is stationary yet physically on the move. you put in your information turn the switch off and the nav functions again normally. however it takes a few seconds for the brain of the car to realize where it is and after that it is back to normal. i love it.
Old Jul 28, 2003 | 02:35 AM
lilitalyx's Avatar
And would you happen to know how much that costs to have done? And one last question, is the shop located in S. Calif by chance?
Old Jul 28, 2003 | 07:02 AM
sachb's Avatar
that actually doesnt cost much at all. no i dont know a shop in s. cal, i live in miami, FL. you want to go to a place that knows what they are talking about so they dont screw the wires up and charge u alot bc the only time consuming part is taking the thing apart. it actually only takes like 20 minutes to do, if the guy knows which wire it is. i advice you to get a hold of maybe the wire diagram for the nav. i dont have one bc the place that did mine knew exactly which wire was the speed sensor. hpe this helps.
sach
Old Jul 28, 2003 | 10:14 AM
AngelC's Avatar
Hey! I'm in Miami as well. Where did you get it done? I've been thinking of doing the same but I didnt know any local shops that could do a good job.
Old Jul 28, 2003 | 05:05 PM
sachb's Avatar
the place is called cartronics its on NE 82 street and Biscayne. Ask for Brenton, and tell theem Sach referred you to them.
Old Jul 28, 2003 | 11:04 PM
shortchaz's Avatar
do you know if the installer just cut the shifter plate to the DIN size or did they make a new one to hold the stereo? Also do you happen to know where the installer attatched the stereo cage to?
best ET: 14.730 @ 96.14mph<P ID="edit"><FONT class="small"><EM>Edited by shortchaz on 07/28/03 08:17 PM.</EM></FONT></P>
