Is there a list of what components fit in our car?
Old Nov 19, 2005 | 08:23 PM
jmX's Avatar
jmX
I've used this forum to figure out what box to buy (4080), which sub (jl10w6) and which amp (500/1)...but now I'm left with the components and an amp for them. I figure I shouldnt choose the amp until I choose the components.
From what I gather, our doors take 6.5" speakers, along with some sized tweeter up top. I'd like to get a set of front components where the tweeter can go right up where the stock one is, and the cover still fits over it. If I have to make a mounting ring for the 6.5", thats fine.
I'd also like be able to order the components online, I hate driving around trying to find stuff around here. New to the area (818).
Suggestions?
Also, do we have 2 side rears, and 2 rears on the back deck? What size are those? I may hook up 2 rears just to have some rear midbass fill.
Jon
06 6MT Coupe
Old Nov 19, 2005 | 11:41 PM
amthar's Avatar
they will take larger than 6.5.. but 6.5 works just fine.
Unfortunately there is really no sizing measurements for tweeters (best I can tell). You want to find one that is rather shallow and does not require a whole lot of hardware to mount up.
sides are 6.5, rears are 6x9. I wouldn't connect any of them, not worth it IMO.
Old Nov 19, 2005 | 11:50 PM
caelric's Avatar
Here is my setup:
PhatBox 40 GB MP3 Player, JL Audio 500/1 Amp, 4080 box w/JL 10w6v2
JL Audio 300/4, Polk/MOMO MMC6500 6.5's up front, DB650 6.5 CoAx in the rear, lots of Dynamat
As you can see, I have the components up front, and coax in the rear. The rear 6x9's are removed completely; they are what Infiniti calls "woofers". You don't need them if you have a good sub (and you do, same as mine), and with them removed, it gives more openings to the interior for the bass to flow through.
There are differing opinions on whether you need anything in the rear at all. I prefer something there, but the fade is mostly to the front, and the rears are only barely audible, which gives me the sound that *I* like, which is what's important. You might try it without any rear speakers at first, and if you think you still need some after that, then you can easily add them.
Dave
Old Nov 21, 2005 | 05:46 PM
excluesiveonez's Avatar
i'd just throw 1 set of beyma w6's in the front doors, and then 2 sets of beyma m6's in the back locations... all threet sets acompanied by a set of kicker r22 tweeters to get up to, join that up with 12 or 15 inch magnum subwoofer and we'd be blasting away
itschuckster
Jul 25, 2015 08:07 AM
Detailed Image
Jul 24, 2015 12:31 PM
Detailed Image
Jul 21, 2015 08:50 AM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
