Pioneer AVIC D1
Old Dec 28, 2005 | 07:08 PM
smknvr4's Avatar
Yes, but if you are going to take the dash apart to modify the lockout then you might as well install the thing yourself. Most of the work is in taking apart the dash. With the right wire kit and adaptors the rest of the install is easy. Then again I guess any head unit install is easy when you've install a few before. I don't have a DVD player so I don't know about DVD playback, but I would image it would work. On the D1 you just need to add a wire and ground it along with the p-brake. the PCB level mod is just for the N2. I've always had it with the mod so I don't know how it is with out it.
Old Dec 28, 2005 | 10:16 PM
barrios35's Avatar
Yeah makes sense. Did you have the VSS hooked up? I have read that you have to disconnect it? Along with the rest of the stuff?
Old Dec 28, 2005 | 10:18 PM
smknvr4's Avatar
No, it's connected.
Old Dec 28, 2005 | 11:30 PM
GsUpHoesDown's Avatar
All you have to do is tap into the VSS wire.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
BfloG35
Oct 16, 2015 05:22 PM
Siciliang35
Sep 18, 2015 11:22 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
