Infinity Kappa series question, please.....
Old Jan 3, 2006 | 11:07 PM
ben_there's Avatar
Anish,
Where did you get those brackets/spacers from that the speakers are mounted on?
Old Jan 4, 2006 | 01:36 AM
GunnerENT's Avatar
What did u use to mount the cross over on the door panel? Just some sheet metal screws?
Old Jan 4, 2006 | 08:18 AM
jeremyp111's Avatar
I just used double sided foam tape and stuck it to the door. Short sheet metal screws work fine though.
Old Jan 7, 2006 | 09:38 PM
MSO4's Avatar
Originally Posted by jeremyp111
Just splice into the stock speaker wires and you are good to go. Run the stock speaker wires into the crossover and from the crossover to the tweeter and woofer.
I'm doing the install right now and can't figure out all the wires.
So from the crossover, one goes to the tweeter, the middle goes to the woofer, but what about the last one. The manual says it should go to the 'amplifier speaker output' but I can't figure out which wire this is on my '05 G sedan.
Should it go to the stock woofer wire or the stock tweeter?
Thanks.
Old Jan 8, 2006 | 12:12 AM
jeremyp111's Avatar
Actually, it doesn't matter. Either one will work fine. It should be a red and a green wire.
Old Jan 15, 2006 | 10:15 PM
Homeslice's Avatar
Originally Posted by ben_there
Anish,
Same question. Those look nice.
Old Jan 15, 2006 | 10:23 PM
anish3232's Avatar
Came like that with the stock bose speaker installed. I think 2003 has that and 2004 not sure on the 04 though. 2005 and on its connected to the speaker. Try going to Infiniti and see if you can purchase it, not sure on if the holes are the same but should be.
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Team STILLEN
Aug 10, 2015 08:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
