Maximum Trunk Dimension
Old Jan 2, 2006 | 03:21 PM
matteod's Avatar
Ok, I asked this question a couple of days ago, but no one could answer it. I will paypal 5$ US to the person that can tell me what is maximum dimension of a 2003 Coupe i.e L X W x H with everything stripped i.e spare tire and all that crap. Thanks
--Matteo
Old Jan 2, 2006 | 07:49 PM
SI_G35Coupe's Avatar
there's no such measurements, because the coupe trunk is very irregularly shaped, even with all the trim panels removed. if you have a coupe yourself it is a relatively quick affair to remove the trunk floor and the sub-floor panels around the spare tire and all you'll need is a 10mm rachet
perhaps you could give us a better idea of what you're trying to do or what specific measurements you need?
Old Jan 2, 2006 | 09:23 PM
matteod's Avatar
I don't have a coupe yet, but I need to move my existing equipment
SUBS
2 x JL Audio 13W7
AMPS
2 x Phoenix Gold XENON 1200.1 (22L x 10.6W x 2.5H)
1 x Phoenix Gold XENON 200.4 (22L x 10.6W x 2.5H)
I'm more concerned about the subs, since my box is 35x 17 x 20 1/4. The amps I'm sure I can stuff them on the inside. Any ideas if this will work?
--Matteo
Old Jan 3, 2006 | 05:34 AM
BlackG35th's Avatar
anything is possible with fiberglass.... jl boxes...nah... i dont know the demnsions nor do i want ur money, but its really hard to find the volume of trunk i mean wen u get it u'll see
Old Jan 3, 2006 | 11:07 AM
matteod's Avatar
Thanks for the replies. Sorry I didn't realize I was asking an impossible question, however I did come across this bit of information found here
"The front mid-ship design lends itself to a spacious interior with 101.4 cubic feet in the passenger compartment and 14.5 cubic feet of trunk space."
So the space is there, now I just have to figure out how to arrange it. Thanks
--Matteo
Old Jan 3, 2006 | 05:41 PM
BlackG35th's Avatar
Matteo, i think thats the trunk size for the sedan with the trunk mats insalled.... probally not a bad estimate but dont base everything off of that
Old Jan 4, 2006 | 01:41 AM
limeg35's Avatar
I dont think there is enough space for pre-made box, especially for two 13W7s, not sure what car did that set-up come out from, but I highly dont think it will sound good in the G, all you gonna get is vibrations and rattles, you can fiberglass them but it will take entire trunk, May I suggest use just one of the sub with decent fiberglass box, you still can have spare tire intact.
Old Jan 4, 2006 | 11:19 AM
matteod's Avatar
Limeg35 is that a 13W7? If so, it does look like two will fit. Also, if I use the 6x9 holes as vents/ports for the sub, this should transfer most of the pressure to the front and should reduce rattling. What do you guys think?
BTW: This came out of a 95 Neon Sedan ( time to upgrade )
--Matteo
Old Jan 5, 2006 | 12:10 AM
limeg35's Avatar
Its only an 10W7 with about 1.1 cbft, dont think remove the 6x9 will reduce much if any rattles at all , I like bass as much as next guy, but with single 10W7 are more than plenty for my taste... I am sure two 13's will fit but you would need an good fiberglassing box adn will use most of the trunk and without the spare tire.
ara777
Oct 25, 2017 01:45 PM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
