Mike's Radar Detector Mount - 2006 G35?
Old Feb 4, 2006 | 07:24 PM
  #31
tomcatm's Avatar
Installed Mike's "upgraded" mount on my 06 premium coupe today. Everything fits great. Thanks Mike!
Old Feb 4, 2006 | 07:45 PM
  #32
mike3348's Avatar
Glad the new designed mount solves the problem.
Mike
Old Feb 4, 2006 | 08:00 PM
  #33
mike3348's Avatar
Originally Posted by jameyb
I received the mount for my X50 from Mike yesterday and it took about 15 minutes to install. Actually the install took about 2 minutes, the other 13 were spent leveling the detector by adjusting the mirror (plus I work extremely slow). Coupled with an invisicord my X50 and mount look so nice and clean, almost as if it was a factory accessory.
Mike makes a good product and ships promptly.
One thing to note if you have an X50:
The radar detector will shake if you do not snug it up against the bottom of the mirror. This is not in any way related to Mike's mount, it is a function of the factory mount piece. As an easy fix, I just stuck a piece of felt to the bottom of the mirror (i.e. between the mirror and the detector) and everything works and looks great!
The female slot in the detector is bigger than the thickness of the male suction cup end that slides into the slot. If you put a slight bow on the suction cup bracket so when you slide it into the detector slot it is tight, the detector won't shake. Just my two cents but it worked great for me.
Mike
Old Feb 10, 2006 | 01:01 PM
  #34
Kryme's Avatar
Mike you have a PM
Old Feb 10, 2006 | 06:31 PM
  #35
luongdmd's Avatar
Mike you have PM......
Old Apr 5, 2006 | 09:42 PM
  #36
MrBig's Avatar
It works on my machine
Mike you got a PM
Old Apr 19, 2006 | 02:36 PM
  #37
itsbo1313's Avatar
Negative Ghost Rider.....
Mike you have a PM
Old Apr 21, 2006 | 10:07 PM
  #38
ksig113's Avatar
Mike, you have PM
Old Apr 24, 2006 | 08:29 PM
  #39
IllusiveG35C's Avatar
Hey does anyone know the circumference of the 04 6mt coupe with the autodim and homelink crap on the mirror??
Thanks!
Old Apr 29, 2006 | 10:58 AM
  #40
No one knows?
Old May 1, 2006 | 09:51 PM
  #41
It would just be lovely if someone could help me out.
Old May 3, 2006 | 10:23 PM
  #42
mike3348's Avatar
So far all the mounts I have sold for all the 04's have had a 3/4 diameter round shaft. Some of the 05 and 06's have the 15/16 sort of oval molded plastic mirror shaft.
Mike
Old Jun 5, 2006 | 07:04 PM
  #43
absolutg's Avatar
workin...
mike, you have PM
Old Aug 17, 2006 | 09:44 AM
  #44
synaptik_1's Avatar
You have a PM Mike
Old Aug 19, 2006 | 01:55 AM
  #45
speedracerg35's Avatar
i think the solution would be to tell him the year and the package of your car in the box at the bottom of your paypal screen.
