Ipod Install (link to pics)...
I have the 30gb video in there now. it just makes it. its really just a matter of where you mount the base of the proclip. it has to be far back enough so that you can tilt the base in order to get the ipod in and out easily. Proclip makes a nicer holder now that allows you to integrate the ipod cable connector into it. that way all you have to do is slide the ipod in with one hand. i may get one.
The white cable is a cable i made from a belkin adapter for apple. I chopped off the cig charger part of the adapter and made an audio cable for input to an auxilliary input to the head unit. The cable also charges the ipod while the car is on.
I have a non-Bose HU btw.
I used an AAI-NIS aux input adapter from http://www.pac-audio.com/ They have a newer one out now that adds more functionality.
Thanks. I used this from Proclip: http://www.proclipusa.com/?sectionpa...oryid=&p_year= and mounted the base to the bottom of the compartment (4 screws w/nuts and washers on the underside). I did have to remove the 2 divider side pieces by grinding them away. The ipod cable comes into the compartment that way. With the mount in place, you dont notice the holes.
