Do I need to use LOC if amp has high volt inputs?
Old Feb 6, 2006 | 11:57 AM
murzik's Avatar
With BOSE HU , do I need to use LOC if amp has high volt inputs?
Old Feb 6, 2006 | 12:50 PM
BoostedConcepts's Avatar
no i dont think that you do
just make sure to get the right wires
Old Feb 6, 2006 | 03:27 PM
el_duderino's Avatar
The signal from the Bose HU to the Bose amp is NOT High Voltage, it's low voltage balanced preamp level.
If your amp can take balanced in, then you can go straight in.
What amp do you have?
Old Feb 6, 2006 | 03:35 PM
murzik's Avatar
I have Infinity ref 7541A. I am going to eliminate BOSE amp. Infinity amp has two types of inputs. To which input I should connect BOSE HU High or LOW?
Old Feb 6, 2006 | 03:39 PM
e420x's Avatar
Mod Junky!
I know its been asked a million times but woulkd the JLAudio CL441dsp be the best bet?
Old Feb 6, 2006 | 04:39 PM
amthar's Avatar
It depends if it takes balanced inputs. I could not find whether it does or does not on any information. You could call JL and ask them.
If you are partial to JL, look at the "slash" series amps. They works very well in our cars when working in an oem integration scenario (keeping stock HU).
Old Feb 6, 2006 | 04:46 PM
e420x's Avatar
Mod Junky!
What Loc are you using ?
Old Feb 6, 2006 | 04:49 PM
amthar's Avatar
I don't. I run the wires straight into my 500/5.
Old Feb 6, 2006 | 04:51 PM
e420x's Avatar
Mod Junky!
From where, the bose amp?
Old Feb 6, 2006 | 04:55 PM
amthar's Avatar
Stock HU ---- (stock output wires that used to go to the Bose stock AMP) ----> [trunk] ---->JL 500/5 (input jacks)
JL 500/5 (output jacks) ---- (stock wires going to speakers) ----> speakers
Old Feb 8, 2006 | 11:15 AM
murzik's Avatar
So how do I connect infinity amp to BOSE HU?
Old Feb 8, 2006 | 12:11 PM
amthar's Avatar
I assume you really do mean Infinity and not Infiniti
Buy a LOC that accepts balanced-differential inputs. Connect the output wires from the Bose HU to the input terminals on the LOC. Connect the output of the LOC to your amp. Connect speakers to amp. You're done.
This has been covered many times in the forum.
Old Feb 8, 2006 | 12:15 PM
e420x's Avatar
Mod Junky!
On another note...something I have not seen much info on. can I use the power from the Bose amp and ground wire and remote to wire another amp in for a sub?
Old Feb 8, 2006 | 12:27 PM
amthar's Avatar
That's because two parts of your question are insane and the second part has been answered before
Insane parts: using the power wire and ground wire for an aftermarket amp. NO. no no no no no. No further questions your honor.
Answered part: Yes, you can use the light blue wire as a remote wire for an aftermarket amp. I probably would not use it for more than one amp. If you wanted to use this wire for more than one amp, I'd use a relay.
Old Feb 8, 2006 | 12:57 PM
murzik's Avatar
Can you recommend any particular LOCs?
