avic d1 bypass question
Old Feb 6, 2006 | 10:35 PM
infinite04's Avatar
i just installed the avic d1 in my 04 coupe and im looking to do the bypass
AVIC-D1 lockout bypass: Find an extra Pioneer wire harness, and pull one of the wires out. Or, if you do not use the A.ANT lead, pull that out of the harness. In the AVIC-D1 harness, there is one open spot on the connector (next to the ground wire). Put the wire into the open spot on the connector, connect the other side to ground, then re-connect the plug to the AVIC-D1. Also, you must ground the Parking Brake wire (or connect to a toggle switch if you feel the need).
now with this method can i ground the wire to the ebrake cable? and is the ground wire next to or below that one open spot? thanx in advance
Old Feb 8, 2006 | 01:36 PM
infinite04's Avatar
nevermind i figured it out and it works great thnax anyways
MastaRip
Jan 4, 2007 11:49 PM
cfulback32
Sep 6, 2005 11:15 AM
