amp & sub installed...few questions.
Old Feb 8, 2006 | 11:48 AM
Back2VQ's Avatar
hooked up my 250/1 & 10w3v2 sub, but I need some more of those members' expertise...
sounds awesome, but!
1. when the car is on, the amp is on, even when the stereo is turned off. i have the remote wire hooked up to the light blue (with silver dots) wire on the bose amp... is there a way to change it so that my amp only turns on when the stereo is turned on?
2. there's a small "whine". obviously it's coming from the amp, since i can hear it when the stereo is turned off. could this be a wiring issue? how do i get rid of this noise? it's very small, and i can only hear it when i'm not listening to anything.
3. what's the best setting for Amp LP Setting, and Bass Control on the 250/1, running one 10w3v2?
i didn't go with a LOC, just tapped into the speaker inputs on the BOSE amp (purple/teal, and blue/pink wires). those are the correct wires to tap into, right?
Old Feb 8, 2006 | 11:58 AM
e420x's Avatar
Mod Junky!
I am considering the same setup. Do you feel that the bass overpowers the stock system too much? Also where did you run your power and ground wires to? Were you able to use the stock bose amps power and ground wires as well?
Old Feb 8, 2006 | 12:15 PM
Back2VQ's Avatar
ran the power wire from the battery through the passenger side, all the way down to the back seats into the trunk. i hooked up the ground wire to the bolt on the far end of the trunk (closest to back seats), there's a bolt that holds some sort of a yellow module (don't know what it is). both wires are 4ga. btw.
i DO feel that the bass is overpowering the stock system, but that's the sacrifice i had to make in order to keep the BOSE HU. i guess i can always control the amp gain so...i'll just have to live with that. still a good setup imo.
Old Feb 8, 2006 | 12:21 PM
amthar's Avatar
Not easily. Why is this an issue? I run a 500/5 like your 250/1 is current connected: on when car is on, off when car is off. Never been a problem for me.
2. there's a small "whine". could this be a wiring issue?
Yes, mine did this too at first. My problem was that the speaker wires and RCAs were right on top of my 4ga. power wire. The power wire was causing interferance with the audio signals. Also, make sure your ground is VERY sturdy. You want to make sure your amp's ground is on a clean, unpainted metal part of the car's body. Don't ground to some taillight screw or something crazy like that.
9 didn't go with a LOC, just tapped into the speaker inputs on the BOSE amp (purple/teal, and blue/pink wires). those are the correct wires to tap into, right?
light green, purple
blue, pink
white, orange
orange/blue, white/blue
are the 8 output wires from the HU going into the stock amp.
Old Feb 8, 2006 | 12:23 PM
amthar's Avatar
you do realize you can change the stock speakers and keep the stock HU, right? That's what I did (see sig).
Old Feb 8, 2006 | 01:34 PM
Back2VQ's Avatar
yeah, looking into replacing my stock speakers with infinity kappa's, but also trying to stay within a budget...
right now all my wires are all over the place...so i should be able to get rid of that whine after i re-route all the wires, right?
Old Feb 8, 2006 | 02:12 PM
caelric's Avatar
The whine could be that, or it could be a ground loop. As Amthar said, make sure everything is grounded to one location, and it is a solid ground. Of course, in your case, "everything" is one amp, but still, ensure it is a solid ground.
Dave
Old Feb 8, 2006 | 02:24 PM
Virge's Avatar
straight to the bank...
Was the improvement significant with simply replacing speakers and adding amps and a sub? I like the DDX8017 as a HU replacement but it seems like more of a hassle to do that (not to mention more expensive)
Old Feb 8, 2006 | 02:28 PM
Back2VQ's Avatar
i would say adding a sub and an amp is definitely a big upgrade from just the Bose system, but still, nothing beats a full system with aftermarket h/u, components, subs, and amps. my car is a lease, and i want to keep things clean with just a few upgrades.
i will try to re-route my ground wire this evening and see if makes any difference. thanks for the help guys.
Old Feb 8, 2006 | 04:41 PM
el_duderino's Avatar
IF you drop the gain to the floor does the noise go away?
Old Feb 8, 2006 | 05:05 PM
Back2VQ's Avatar
just to make sure, are you refering to the gain on the amp?
Old Feb 8, 2006 | 06:00 PM
amthar's Avatar
yes he is. What other gain is there?
Old Feb 9, 2006 | 11:18 AM
Back2VQ's Avatar
I still get the "whine" with the gain all the way down, and also with the RCA's pulled out. definitely ground wire issue then? haven't had time to relocate the ground wire...
Old Feb 9, 2006 | 12:25 PM
16psibrick's Avatar
where is the whine coming from?
in some cases, and i have seen this quite a few times and its kinda strange, is that sometimes when you tap into stock systems and wires, it causes engine noise to be transmitted from the STOCK mid/high spekares, and sometimes they will even makle the while wtih the stereo OFF...
so you are sure the whine is coming form the sub?? thats hard to believe because most of alternator whines are in the midrange freq., and the low pass filter on the amp should have cut out most of not all of it before it reached the sub
b
Old Feb 9, 2006 | 12:35 PM
He asks a good question - did you say the whine is coming out of the sub or out of the OEM Bose speakers?
