Subs firing in the trunk
Old Feb 19, 2006 | 11:23 PM
saltydogg05's Avatar
Is there any special reason most owners have their subs firing into the trunk? (INSTEAD OF FIRING TOWARDS THE CABIN)
Old Feb 19, 2006 | 11:26 PM
e420x's Avatar
Mod Junky!
depends on what box setup you go with
Old Feb 19, 2006 | 11:27 PM
non ported... custom installed box.
Old Feb 19, 2006 | 11:29 PM
e420x's Avatar
Mod Junky!
if you look most people go with a 4080 box, seems like a common setup. The sibs firing into the cab use the airspace in the trunk to create the sound partially
Old Feb 19, 2006 | 11:35 PM
My installer wants the subs firing towards the cabin.(2 infinity 10 vq's). Is there an advantage or disadvantage to have them installed this way?
Old Feb 20, 2006 | 03:12 PM
trackmagic's Avatar
I have my subs firing down into the spare tire area. The floor is a pretty simple custom one that looks stock but is cutout beneath the box. Downside is noone can see your subs.
Fyi, I have 2 12" Rockfords
Old Feb 20, 2006 | 10:43 PM
If the subs are firing into the trunk are wouldnt that kill the bass if your trunk is sealed off...like if you were to use a ZENCLOSURE box?
Old Feb 21, 2006 | 12:20 AM
Brent's Avatar
The reason for firing sub into the trunk is it corner loads them and increases the bass output as long as trunk is not completely sealed from cabin. The disadvantage is some loss of tightness in the bass. Firing into the cabin does the opposite.
Old Feb 21, 2006 | 10:58 PM
Thanks brent, now I'm gettin what I was lookin' for!
Old Feb 28, 2006 | 06:10 PM
badtziscool's Avatar
A question along the same subject. If you were to have the subs firing into the cabin but with the rear seat up, would that affect the sound terribly? I mean would the seat dampen the bass volume?
Also, I don't have the bose option so I don't have those rear deck mounted speakers. Does that mean my trunk is completely sealed from the cabin?
Old Feb 28, 2006 | 11:44 PM
BigSash's Avatar
if they fire the subs into the cabin they need to take extra steps to completely seal off the top deck and make it secure.
a lot of audiophiles argue for firing into the cabin and i have seen illustrations and what not to back up their point of view, others say firing back is better, all those guys have their own schticks.
go on google and search "should subs fire into the cabin" bet you get a good answer
Old Feb 28, 2006 | 11:59 PM
shooter's Avatar
It's not the critic......
I have a 4080 box (fires into the trunk) and there is a noticible increase in spl with the seat down. Not a huge amount, but noticible.
If you are interested in clean, tight bass, I suggest you also work on sound deadening to decrease rattles and vibration. It amazes me how much sound quality is lost in a "live" car.
What does "corner load" mean?
Old Mar 1, 2006 | 01:07 PM
BigSash's Avatar
More on firing back or front:
the way it was explained to me
if you fire into the cabin, some of the bass waves still travel to the back of the trunk then bounce back forward and come in out of phase with the rest of the bass. Something like 80% goes through and 20% bounces off the back of the trunk and comes in out of phase.
Some argue that if you fire into the trunk it bounces back in phase, but I think you will still get some bass coming around the box initially that never bounces off the back of the trunk and then you will be even more out of phase.
Maybe some1 with a little more expertise can state this more clearly, or shed more light on it, but that is more or less what i was told.
Old Mar 1, 2006 | 02:11 PM
LjN_728's Avatar
Just think of your trunk as a large enclosure because that's what it basically is. Two types of bass: Nice clean bass or the type the resinates. If I were you, I'd test out both setups and see what kind of sound you would enjoy
Old Mar 3, 2006 | 12:46 AM
I went with the subs towards the cabin. The bass is tight. There is hardly any diff. with the seat up or down. I would love to listen to a G with 4080 or Zenclosure to see how much diff. there is, but there are no other G's in my town. My Nickelback CD sounds awesome but the rap and hip-hop does not have the boomy, lingering bass that my Tahoe once had. I still have some adjusting to do on both the amps go get the input levels where I want. I went with Kappa comps in the front, Kappa 3 way in the rear deck...both sets run with an Infinity ref. 540 watt amp. The 2 subs are Infinity Kappa Perfect 10vq ran by a 1200 watt Infinity mono sub amp CLASS D. I disconnected the 2 rear floor bose. ( For now I still have the fac. head unit, replacement of the HU will be in June). Sounds pretty darn good though, I just wish I could hear someones subs firing to the trunk.
