Navigation 'No Data' Error, Help
Old Feb 20, 2006 | 05:03 PM
Waz's Avatar
Waz
Exclamation Navigation 'No Data' Error, Help
Hello,
I have an 04' coupe with Nav. I recently purchased a Zenrin updated map dvd rom for the navigation. I went from version 6.2 to version 6.4. The mapping works, however, when I try to input a specific address and change states, the return is 'No Data'. So I cannot select a different state other than the default (california) for address point to point routing. I placed my 6.2 disc back in the unit to make sure that the computer itself was not causing the error. 6.2 works fine. Any solutions, suggestions, please respond.
Waz
Old Feb 21, 2006 | 11:03 AM
Beowulf's Avatar
Hrm well thats not good. I would probably try to contact Zenrin first then you could try your dealer...
Old Feb 21, 2006 | 01:27 PM
tomcatm's Avatar
Did you try setting the region to another state?? There is a screen with the map of the US with different states grouped together. I remember the dealer set mine to the TX, OK, LA, MO grouping from the default Cali when I took delivery. Maybe that will help?
Old Feb 21, 2006 | 02:06 PM
Waz's Avatar
Waz
I found out from Zenrin that there is a firmware upgrade that needs to be installed in order for the new 6.4 disc to work properly. Navigation Upgraders beware if buying a new dvd from an alternate vendor such as ebay!
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
MThawkins86
Oct 24, 2015 02:07 AM
