Dead Car But Battery Is Good!
Old Apr 17, 2007 | 01:34 AM
Amit's Avatar
Originally Posted by MyLilBlkG
well i checked the fuse and they're all good. i will get my hand on a voltmeter and check the voltage.
While checking teh battery links i decide the whack it one more time (just to vent) and the power went back on. I was like WTF and went to start it and it started. Shut the car off and tried it two more time and it turns on. SO now i'm just scratching my head.
can there be anything wrong with the ignition wiring? basically when i try to crank it, that's when the power goes out. i though it was when it is in the "on" position but it happens more often when i try to crank the ignition. After i crank i hear the buzz/click sound similar to when you try to crank the engine without power. a split second later the power goes dead while i'm holding the key in the crank position.
thanks for all the responses
You problem sound a little different from what myself and imRACERX had. I would check for loose wire. Usually when a wire is loose it would do what your car is doing right now.
Old Apr 17, 2007 | 02:03 AM
MyLilBlkG's Avatar
i checked the voltage and it's good as well. today i decided to change out the battery (just in case) and it seems good so far. it hasn't shut off on me yet...now that i said that i just jynx myself lol.
hopefully all will be well
thanks for the responses
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
SIKKI
Jul 21, 2015 01:55 PM
Tylerttn
Jul 13, 2015 04:26 PM
