Neon
Old Feb 27, 2006 | 06:20 PM
MikeyMike's Avatar
Rollin On Dubz
I'd go with white...
Old Feb 27, 2006 | 07:26 PM
Diesel1's Avatar
Moderator
Originally Posted by G352NV
Thanks Ill check into that. The idea is to have sheet metal under the car and checker tiles around that as a boarder. I think the light would look tight under the car hitting the metal.
Now you jus opened a can of worms! You now doubled your detailing time! LOL Now the underside will have to be just as clean as the top! LOL
Should look sick though!
Old Feb 28, 2006 | 12:15 AM
SI_G35Coupe's Avatar
Originally Posted by limeg35
The only problem with the neon/led is that you have to find a place underneth the G35 to install them out of sight, will be hard to find space under the G35 for the normal size tubes, if you go small(2~3ft) it might not be bright enough.
his body kit should be able to hide the tubes fairly well. with the LED kits i think you can fade from blue to white on a timer, might look cool
Old Feb 28, 2006 | 03:34 AM
BigSash's Avatar
all u people even saying the word ricey in this thread are crazy.
My money says G35NV has one of the top Gs out there. and it's not ricey look at his audio install thread. Guy is a master craftsman =]
Old Feb 28, 2006 | 03:58 AM
luongdmd's Avatar
dont' do it....
Old Feb 28, 2006 | 04:11 AM
Strtsk8r321's Avatar
I think neon would be cool if you cant actually see the tube. Who cares if its $99. What about all these $75 pop chargers and stuff?
Old Feb 28, 2006 | 04:39 AM
limeg35's Avatar
G35Lin have on his Show car...
Old Mar 2, 2006 | 09:42 PM
zein's Avatar
underbody
Hey I got underbody led's on my stock G coupe and I don't think it looks that bad, and its only ricey if you drive with them on. I usually only turn them on with I'm parked and just wanna show them off. Here's a good pic to show what it looks like. I decided to go for led's just cuz I know that they last longer and you can get nice little patterns with them unlike neon. But I've seen my friends cars with neon and although they are a little brighter, but you can barely notice the difference. The tubes are also really easy to hide on the G's so that shouldn't pose much of a problem.
Old Mar 2, 2006 | 09:53 PM
G352NV's Avatar
Never enough
What kit is that?
Old Mar 2, 2006 | 09:58 PM
zein's Avatar
The kit that I'm using in that picture is the Streetglow Multi Color LED Kit. I couldn't decide on a color so I just went multicolor and its great.
Old Mar 2, 2006 | 10:04 PM
I really dont thing its ricey if the right choices are made. (ex. placement, color, effects)
Old Mar 3, 2006 | 12:33 AM
nicko916's Avatar
that was me in Elk Grove i had a few personal issues and disappeared for a while.. if you still want to see the vid g352nv please PM me
Old Mar 3, 2006 | 01:01 PM
mtong's Avatar
I'm in the process of installing a Streetglow (single color) LED kit ...
Biggest benefit of LED over neon is that the LEDS will last a long time and like what the others have said, LED's can be controlled. My install is about 75% finished, trickiest part was finding areas to fish the cables back into the car.
Good luck!
BTW how is your audio install going? I just started on the audio upgrade on the G ... it has been pretty tiring, I give you props on the work that you have done on your car!
Old Mar 3, 2006 | 01:17 PM
G352NV's Avatar
Never enough
Thanks. Please post pics when your done. My install is done for the most part. The Xbox is giving me a bit of trouble. Just need to put some time into it.
Old Mar 3, 2006 | 02:51 PM
  #30
BigSash's Avatar
damn that bastard xbox!
