300/4 & 500/1: Anyone have this setup?
Old Mar 10, 2006 | 09:14 AM
BocaCoupe's Avatar
G's Up, Ho's Down
I'm going to go with a 300/4 & 500/1 amp for my G35 Coupe. Does anyone have this setup? I wanted to put them under the left plastic next the the spare tire. I'm wondering if it will fit and if anyone has any pics of this setup installed.
Thanks guys!
Old Mar 10, 2006 | 09:32 AM
amthar's Avatar
You probably can't fit them both, unless you build some sort of rack that lets you stack them on top of one another. It's going to be really tight. You could possibly fit one on the left under the plastic support and one under the right under the plastic support. Dunno. I know one would fit there no problem, two will be tough.
Old Mar 10, 2006 | 09:35 AM
e420x's Avatar
Mod Junky!
Most likely not, the 500/5 barely fits in there
Old Mar 10, 2006 | 10:11 AM
BocaCoupe's Avatar
G's Up, Ho's Down
hmm... I guess this is gonna be harder than I expected....
Old Mar 10, 2006 | 11:42 AM
dwell's Avatar
I have this setup. If it turns out they don't fit in the stock amp location they will fit mounted side by side on the back of the rear seats.
Old Mar 10, 2006 | 06:33 PM
jeremyp111's Avatar
I currenlty have a 250/1 and 300/4 mounted on the rear seat back. I had planned on upgrading to the 500/1 (which just came in today) so I will be replacing the 250/1 and put the 500/1 in it's place. The 300/4 and 500/1 fit side by side on the rear seat back as suggested above.I used 1/4" thick 2" wide MDF slats that I slid behind the seat back to secure the amps. They are heavy $@!*&%# amps.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
JustinMKN1
Sep 18, 2015 03:40 PM
