DLS UP6 crossover jumper settings
Old Apr 4, 2006 | 01:51 PM
MWhy's Avatar
Can anyone recommend a tweet jumper setting(crossover) for UP6's? From the factory, they're set to low. In a G Coupe, would middle or high be better, or is this just a preference thing?
Thanks!
Old Apr 4, 2006 | 02:41 PM
amthar's Avatar
Thanks!
One of the main reasons I bought the DLS UP6 was the ability of the tweeters to play lower frequencies than most tweeters I've had experience with. This ability to play low frequencies is especially helpful in the coupe because it reduces "float"- the effect that the tweeter and woofer sound like they are apart and thus sound is coming from two different locations (commonly caused when the tweeter and woofer are not physically together, like our coupe's are configured).
Ror this reason I run them low and I cannot distringuish any floating.
Old Apr 4, 2006 | 04:40 PM
MWhy's Avatar
Thanks Amthar. I'm curious...how did you mount your tweets? Did you just remove the stock ones in the sail panel & jerry rig the DLS ones into place?
Old Apr 4, 2006 | 04:50 PM
amthar's Avatar
Yes. I used a metal ruler from Staples, one of the ones with cork on the back side. Cut two pieces long enough to go across the backside of the tweeter. Drilled two holes to line up with the stock mounting posts of the stock tweeter. Transferred the stock screws, works like a champ. You may have to cut off the DLS UP6 tweeter guards. I didn't, instead I just rotated the tweeter so it pointed more towards the front seats and this orientation made them fit. That's the best I can explain it.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
