2005 Bose Amp 12V Turn-On Wire
Old Apr 11, 2006 | 07:13 PM
JWise1203's Avatar
I have read through the forums and most suggest using the sky blue colored wire for a turn on lead. Using my multimeter I only got about 6.1V from this wire. I know most people here have a Coupe, so I decided to research a little further.
I looked in the service manual for my year and it said that the wire color should ber G/W (Which I am assuming is Green/White).
The 2004 Coupe service manual said that the wire should be SB (Sky Blue).
My question is, am I correct that I should tap into the G/W wire? Those who have Sedans, what have you done with your installs?
Old Apr 11, 2006 | 07:19 PM
el_duderino's Avatar
Wait a minute... you've got a multimeter, right? What did the wire test?
Old Apr 11, 2006 | 07:23 PM
JWise1203's Avatar
I still need to test it. I came inside to do some research. If it reads 12V I know I should be safe, but I wanted to double check here to confirm. Anyone?
Old Apr 11, 2006 | 09:18 PM
JWise1203's Avatar
Well I went out and checked the wire ... I was getting 12V ... so I went ahead and tapped into the wire. It works great. My computer power supply turns on and off automatically with the car.
If you have a Sedan, look for the Green and White (G/W) wire (not Sky Blue) right at the Bose Amp for ACC power. Of course, test with a multimeter first to be sure.
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
migurus
Sep 5, 2015 09:39 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
