No sound after double din install
Old May 8, 2006 | 11:04 PM
LT1 SS's Avatar
I pulled my kenwood ddx 7015 out of my '98 pathfinder. I have the bose system in my '06 coupe and i'm not getting any sound out of the speakers after putting it in. I'm guessing it's because the amp isn't getting a signal from the receiver. Which wire needs to be connected from the receiver to amp. Could it be something else?
Old May 9, 2006 | 01:28 AM
ttrank's Avatar
Grocery getter
Did you connect the amp turn on and amp ground at the back of the deck?
I just did an install on a friend's bose 05' and it worked fine...
Old May 9, 2006 | 06:46 AM
LT1 SS's Avatar
thats what i'm looking for in the harness. which wires are they? is it in the set of wires that don't connect to the head unit?
Old May 9, 2006 | 10:43 AM
SFLG35's Avatar
FGC President
when i installed me 7015 i could only get sound when i put it on the radio.
i moved the antenna wire over to the amp turn on wire from the ddx and then i had sound on all the inputs.
Old May 9, 2006 | 11:27 AM
ttrank's Avatar
Grocery getter
If you used an adapter harness there should be a power antenna wire (blue), amp turn on wire (blue/white) and an amp ground (black/white). I connected them all both times.
All the wires are on the two audo harnesses.
Old May 9, 2006 | 09:33 PM
LT1 SS's Avatar
I'll look at the harness again. The audio is the smaller one right?
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
EPG35
Aug 16, 2015 04:52 PM
Frankieg35
Aug 15, 2015 10:49 PM
itztwinki3
Aug 1, 2015 12:58 AM
kd03g99
Jul 30, 2015 11:24 AM
