Ipod installation pictures?
Old May 16, 2006 | 02:36 PM
LightsOutG35's Avatar
WOW! All of these mounts look really good.
Old May 17, 2006 | 01:52 AM
sage's Avatar
Originally Posted by Dark Genesis
Heh, I just bought an Ipod just 2 days ago, I'm planning on using it in my car but I don't know what equipment I need, can someone help you out? The search feature is sorta hard to use when I type in Ipod and stock....
Type 'USA Spec PA11-NIS' into the search and you should find a lot of info.
I would suggest getting the above mentioned hardware as well as a clip from Pro Clip.
Old May 17, 2006 | 05:18 PM
sonofsnood's Avatar
for the Proclip users, i read the instructions that there is some type of adhesive in use, is this the case and did you guys use it?
is it easy to remove? is there some type of clip in use at all or is it all tape?
i'd really like the flexibility to remove it if m ipod breaks or something
Old May 17, 2006 | 05:26 PM
zackt69's Avatar
rarejdm.com
It has an adhesive tape on the back, but I didn't use it - just clipped it on. So far no problems. I have the same proclip setup as the pics MISTIKMACK posted.
Old May 18, 2006 | 02:43 AM
sd_diver's Avatar
Totally hidden
I have mine in the upper cubby. I pretty much use playlist mode, so there is nothing to see. However, when I use direct mode (the switch in the 2nd picture allows me to change modes) and want to see the ipod, I simply use the belt clip on my ipod case to clip it to the base that the Nuvi plugs into. Allows me to swivel it to any angle.
sd_diver
Attached Thumbnails Ipod installation pictures?-60362095.jpg   Ipod installation pictures?-60362096.jpg
Old May 18, 2006 | 09:37 PM
MISTIKMACK's Avatar
Yeah, the adhesive tape is not needed to hold the whole thing intact.
Old Jun 2, 2006 | 05:56 PM
bradakrez's Avatar
DIY for installation of ipod in 05AT (PAC)
https://g35driver.com/forums/showthread.php?t=99632:)
Old Jun 4, 2006 | 09:25 AM
Real_G's Avatar
An Army of One...
Ipod DIY w pa11-nis
https://g35driver.com/forums/audio-video-electronics/86108-installed-nano-w-proclip-w-pa11-nas.html
Old Jun 4, 2006 | 08:47 PM
reelfreak's Avatar
Just made this this weekend for my nano. Used 1/4" wood, cut out the shape, covered it in leather (appropriated from an old laptop bag) Looks pretty good I think.
Old Jun 4, 2006 | 08:52 PM
BigSash's Avatar
now that looks nice. very good work reelfreak
Old Jun 4, 2006 | 09:33 PM
JEVERYDAY's Avatar
WOW. That looks real custom man... NICE !
Old Jun 6, 2006 | 06:51 PM
pappa_shango's Avatar
How is the connection on these? Sound quality, etc. Can you get the same quality as you would playing a regular CD? My brother hooked an ipod up in his Exterra and it has a constant buzzing noise. I'm picking up a G35 in two weeks and I want to put one in immediately so I need to purchase it ahead of time. Its sound like PA11 is the way to go???? Any feedback or info would be huge! thanks!
Old Jun 6, 2006 | 06:54 PM
zackt69's Avatar
rarejdm.com
sounds great... no buzz at all -
Old Jun 6, 2006 | 06:55 PM
how difficult is the wiring process on these?
zackt69 did you use the PA11?
Old Jun 6, 2006 | 07:04 PM
  #30
cokecan's Avatar
The PA11 itself takes two minutes to figure out. Has two connectors, one that plugs into where a cd changer would go (and were the pre-wiring for the SAT goes) and the second connector is a passthrough to the main wiring harness (which is where i'm guess it gets power from).
Mounting your Ipod in some places could take more then others..
