Power Source in Sedan Trunk?
Old May 14, 2006 | 04:23 PM
Gordgee's Avatar
Administrator
Question Power Source in Sedan Trunk?
A quick question.
Does anyone know if there is an easy 12 volt wire to tap into in the trunk that is either keyed on, or non-switched (always live)?
Preferably at the top of the trunk area as I want to run a small power wire to my Blue Tooth GPS receiver that I use with my Palm Pilot. It doesn't have to run much current as it simply provides power/charge to the receiver.
I noticed the amp back there, and I suspect that I could tap off that, but before I poke a hole into several wires, I thought someone here would know the colour, etc. or another easy source.
Thanks In Advance.
Old May 14, 2006 | 04:51 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Gord, there is also a switched hot that goes to the antenna booster.
It's controlled with the HU
Old May 14, 2006 | 05:22 PM
Gordgee's Avatar
Administrator
Thanks. Actually, I just measured the out-put for the wire supply for the receiver. It's only about 5 to 5.5 volts. I should have done this prior to my question.
I suppose I could use a transformer and hook it to the 12 V supply, but if you know if there is one that is 5 to 5.5 volts (not sure if there even is one), it'd make my job easier.
TIA
jsimonk
Dec 22, 2023 03:49 PM
tal1412
Nov 28, 2022 09:25 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35_EAZY
Jul 19, 2015 01:38 PM
