Sedan SAT Pre-wire ... where?!?!
Old Sep 17, 2003 | 01:27 AM
THX723's Avatar
G Kreuzer
I've got an '04 Sedan 6mt. It's also got the pre-wire sticker, but I can't seem to locate the darn SAT pre-wire harness. I've disasesmbled the *top* lining in the trunk and expose the area where the amp resides, but no SAT harness in sight What a bummer. I'd thought the whole SAT pre-wire fiasco was over with for the '04s.
Any knowledgeable Sedan owners care to indulge as to which crevices this harness resides?
THX723
Old Sep 17, 2003 | 05:48 AM
THX723's Avatar
G Kreuzer
Re: Sedan SAT Pre-wire ... where?!?!
Hours later, I was able to dig much deeper and managed to finally locate the elusive SAT pre-wire harness that indeed exists!
For you sedan people out there that falls under the factory 'pre-wired', the earlier assumptions by some other posts as to where this harness may be next to the Bose amp was false. The actually location turned out to be rather easy to gain access to. It is located directly behind the rear-passenger seat panel. It'll be apparently obvious if you lift the carpeting material. Look near the lower right portion against a metal structural beam.
Good Luck!
THX723
Old Sep 17, 2003 | 03:29 PM
butlermd's Avatar
the sat wire is near the amp in the COUPES only. for the sedans its as you indicated.
jb
mostestG35
13
Aug 15, 2015 05:56 PM
Mac8008
Aug 4, 2015 09:19 PM
Frostbite91
Aug 2, 2015 04:59 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
