Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
AutoX Class question
Old Aug 20, 2005 | 10:53 PM
G35Maxedout's Avatar
FS: OEM 18" W-n-T
Question AutoX Class question
If I add these to my Stock G35, would I run SCCA STX or BSP Class?
I think these replacement A-arms would do wonders for handling..
What do you think?
Old Aug 22, 2005 | 11:21 AM
lloyd's Avatar
The camber adjustment would be great, and depending upon what else you do to it, will move you into STX. Just remember that there are other limitations to staying in STX, such as tire size and type. If you change the tires to R compound for instance, you move into BSP. In my area there are some very well prepared BSP cars, and drivers, competing. For an overview of the requirements check out:
http://www.scca.com/_filelibrary/Fil...categories.pdf
Old Aug 22, 2005 | 02:53 PM
FS: OEM 18" W-n-T
I'll planning to use the above arms and Falken RT615 tires and replacing stock shocks with coil overs. Dialing in 1-1.5* of negative camber front and rear. Replace w/ Z-tube and K&N Filter and lastly Hi-Flow Cat with Tanabe Cat-back Exhaust system. All allowed in STX. This should make this car a beast. I used to autoX a BSP Corvette in the day, back in early 80's and then a SuperStock 1985 Corvette in the late 80's & early 90's before taking 10 years off. I'm back and ready to have some fun.
Old Aug 23, 2005 | 05:23 PM
lloyd's Avatar
G35Maxedout, you must be almost as old as I am. Almost....
Old Aug 27, 2005 | 05:02 AM
leakytwot's Avatar
you know what else does wonders for handling?????
don't cheap out and spend the cash for a BMW
Old Aug 27, 2005 | 12:32 PM
roneski's Avatar
Devil's Advocate
Who let the troll in? Go to off topic if you want to act like an a**.
Old Aug 27, 2005 | 11:28 PM
Triple8Sol's Avatar
Is that correct? From how I'm reading it, it looks like those are the categories for Solo I, whereas AutoX is classified as Solo II. Or am I just misreading it somehow?
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
