DIY : Possible creaking seat fix
Old Apr 3, 2007 | 03:40 PM
gramdacious's Avatar
I still have yet to feel it rock! By the way, if you raise the seat as high(and it goes high) as it can go, you'll easily see and be able to access the three bolts.
Old Apr 4, 2007 | 11:48 AM
DaveB's Avatar
Originally Posted by gqong
i hope this works for the coupe too, i beleive the rails should be the same. it really is bugging me...hey daveb in steps 5-7 can you point out the screws for each that would be the best. i am somewhat unsure of which to try but i still have not tackled it yet which may be the reason for the point of confusion. if not no prob im sure once i take a look it should make some more sense.
You need to loosen the two nuts and one bolt. In the picture you see two bolts in vertical position at the base of the seat support. Loosen those two nuts. The forward one is 12mm and the aft is 14mm. The bolt you need to loosen is pictured, but all you can see is it's threading about 1.5" to the northwest of the forward 12mm nut. Access to the bolt is just below the outside trim cover assuming you've raised the seat to it's highest position. As gramdacious pointed out, you don't need to remove the trim cover if you raise the seat. To perform the fix, all three bolts/nuts must be loosened to gain the most play and adjustment.
Old Apr 4, 2007 | 11:53 AM
gqong's Avatar
^ Thanks for clarifying I think I got it now hopefully I can find some time to give this a shot tomorrow. Will let you know how it goes and hopefully the same fix for the coupe.
Old Apr 5, 2007 | 11:37 AM
gqong's Avatar
I just did this same thing on my coupe! it WORKED perfect! well i just did a quick run aroudn the block and it was night and day. THanks again DaveB i will update later when i take it out for a bit longer.
Old Apr 5, 2007 | 11:58 AM
TonyD's Avatar
Nissan/Infiniti just needs to resolve this issue as a whole. In my Z, in my Altima, in my Murano, in my Maxima, and in my G all the drivers seats had the rocking issue. Its BS and it they should fix them even if you are beyond warranty period. You would think that having the same issue over their entire product line would raise a freakin flag...
Sorry...rant = off.
Old Jun 25, 2007 | 05:59 PM
STLTHSDN's Avatar
Just to add to this, i did this and while in the process of doing this fix i added some teflon washers from my local auto parts store, what aq dream it is to drive my car now, the squeak was an incredible nuissance but now its golden silence.
Old Jun 25, 2007 | 08:50 PM
rockd's Avatar
where did you add the washers? any pictures?
Old Jun 27, 2007 | 05:50 PM
STLTHSDN's Avatar
I just fired thru a pile of bins at the local nut and bolt store. didnt take long to find what i was looking for.
Old Jul 11, 2007 | 10:02 PM
BocaCoupe's Avatar
G's Up, Ho's Down
This worked perfectly for me. Didnt need to remove the trim pieces. I used wrenchs not sockets, maybe thats why. Easy, Easy, Easy, THANK YOU SO MUCH U SAVED ME A TRIP TO THE STEALERSHIP!!!!
Old Jul 12, 2007 | 06:04 PM
DaveB's Avatar
I'd consider submitting this to my dealership as a technical service bulletin, but I'd know I'd get that look from them like I don't know what the hell I'm talking about. It's the same one I get when I tell them to update my transmission software with their Consult computer. Sometimes it amazes me that most of these techs can't think outside the box when it comes to fixes like this. Doesn't it make a little more sense to adjust the seat frame a bit rather than spending $500+ to replace a seat frame that isn't the problem to begin with
Old Jul 13, 2007 | 01:40 AM
zackt69's Avatar
rarejdm.com
Sweet... this is perfect, my seat just started this today! Thanks!
Old Jul 13, 2007 | 08:36 AM
BocaCoupe's Avatar
G's Up, Ho's Down
LOL... ok now it came back. Any suggestions?
Old Jul 13, 2007 | 04:01 PM
DaveB's Avatar
Adjust it again. Maybe put a little tension on the seat itself while retightening the bolts.
One thing I've noticed is that this problem is heavily influenced by humidity. If it's been rainy for a day or two, then I'll sometimes get a faint creek. Once the air drys out, the sound disappears.
Old Aug 12, 2007 | 09:03 PM
rockd's Avatar
this fix worked at first, but then the creak/squeak came back. tried it again numerous times, but it's still there... i'm going nuts, seriously...
Old Aug 13, 2007 | 02:29 PM
  #30
EG62G35's Avatar
that sucks.. someone help this guy
