DIY: how to mount projectors
Old Apr 8, 2007 | 11:40 PM
IvoryGT's Avatar
this is just a quick DIY on pre 06 model headlights. This is how I've done, it's not the only way to do it, but I found this to be the most accurate rotational wise and also easy to aim with precision.
I will take better pictures when I get my camera...i lost my old one..
here's the stock mounts with the reflector
here's the reflector removed and projectors mounted
here's side profiles
the projector of choice is TSX, what I have done is remove the reflector, drilled holes on the bottom nipple. They are large enough for the bolts to fit through and fasten them with nuts on the stock mounting points. This way the rotating is perfect horizontally.
comparison for how much they stick out
finished mounts with 2 projectors
(it's just for demo, they are not really fastened on there tight)
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
