DIY: Painting Door Pulls (100% pictorial)
^The Duplicolor comes in different colors. If you wanted a factory looking finish though, primer and paint would be the way to go. Only problem is then it's just as easy to scratch as the factory finish. The advantage with what I used is that the stuff is very durable as long as you do proper prep work
I really liked the alcohol diagram, very funny! Just a couple side notes for everybody, you don't have to use dupli-color interior paint, you can use any kind of spray paint you like, as long as you properly prep the substrate (trim piece) as shown. For that question about color matching...I'm pretty sure Nissan releases their interior trim colors to the major paint companies. As a result, you should be able to go to any auto body supply shop and get a small touch-up spray can that should match the trim color of the interior. You're gonna need to look through the chip books at the store, or check online (a good resource is tcpglobal.com) to get the color code.
^As an addendum to the side note: you can indeed use other paints, however, if you do, you’re going to need to prime the surface with a very good primer. If you use conventional spray paint on bare plastic, it will chip. (if it even bonds in the first place) The reason I recommended the dupli-color vinyl and fabric coating is because I have had experience in the past using this product, as well as a typical prime-and-paint solution. The dupli-color is more wear resistant and by far more chip resistant than any other solution I’ve found (including the factory finish)
If you wish to color-match though, conventional spray paint is your only option, but doing good, thorough prep and priming as well as a strong clear coat are all essential in such a high wear area.
^As an addendum to the side note: you can indeed use other paints, however, if you do, youre going to need to prime the surface with a very good primer. If you use conventional spray paint on bare plastic, it will chip. (if it even bonds in the first place) The reason I recommended the dupli-color vinyl and fabric coating is because I have had experience in the past using this product, as well as a typical prime-and-paint solution. The dupli-color is more wear resistant and by far more chip resistant than any other solution Ive found (including the factory finish)
You can actually paint onto bare plastic if you prep the substrate properly; all you need to do is clean it, scuff it, clean it again and then spray one good coat of primer before you paint it. I've done it while redoing several different car interiors for people, including my car. Just FYI to anybody out there that wants to do some interesting color that they can't find in Dupli-Color fabric/vinyl or SEM paint.
I actually forgot to mention something in that post. There is another paint besides Dupli-color, it's called SEM Colorcoat. It's the professional stuff, and comes in at least 25 different colors. It's even more durable than the Dupli-color stuff (can't scratch, chip or mar the paint without damaging the actual plastic substrate too), it has significantly better coverage, and a lot less surface prep is needed b/c the SEM paint sticks to pretty much anything that's even remotely clean.
--edit: Thanks Chris
