DIY LED headlight thread
Old Jan 15, 2011 | 02:44 PM
redpearl99's Avatar
any suggestion as to how bright the LEDs should be?
5000mcd? 10000mcd? i have no idea
i don't want them to overpower the headlights, but i don't want them to look too weak either
Old Jan 19, 2011 | 09:19 PM
Kenny_Cox's Avatar
quick, quick question. when baking the headlights, and pulling them apart. you just leave the factory silicone on there, then rebake and put them together? No new silicone needed?
thanks
Old Jan 20, 2011 | 11:17 PM
ryno23's Avatar
wish i wasnt scared to attempt this lol
Old Feb 16, 2011 | 06:50 PM
tweger's Avatar
thanks
I've pulled them apart 10+ times by now and have never used new silicone, no fogging either. You should be alright just using what's there.
One recommendation though, that **** gets everywhere. You'll have to wear gloves while taking them apart since they'll be extremely hot, I just wore cheap mechanix gloves.
Old Mar 17, 2011 | 01:51 AM
laksjd84's Avatar
i recommend you drill the holes before you prime/paint.
Old Mar 22, 2011 | 11:10 PM
JOHNNY CASH's Avatar
Good job! Your headlight setup is the sh*t!!!
Old Mar 22, 2011 | 11:15 PM
nissandrifter32's Avatar
They look awesome...
Old Mar 23, 2011 | 12:52 AM
So if one LED goes out, then the series of LED goes out too. Wow!
How many times did you have to change set of LED's? That seems to much of a hassle. But I'd want to take on this project.
Are LED fragile?
Old Apr 13, 2011 | 09:49 PM
erral's Avatar
Thats cool! good writeup
Old May 18, 2011 | 05:41 PM
Kaleb_24's Avatar
What kind of paint did you use to paint the housing!
Old Jun 29, 2011 | 06:42 PM
tweger's Avatar
Hey guys, just as a little update:
A year later and the LEDs still look great. Only downside is use something other than velcro to hold them in, they kind of recess because it wasn't sticky enough to hold them in. Also, one set of LEDs has gone out recently, no big deal, just have to pull them apart and play with it some more.
And to answer about paint, I used high temp flat black paint from Kragen (O' Rileys). I doubt it really needs to be high temp paint, but I like the color the best out of all the flat blacks I've used.
Old Aug 31, 2011 | 05:08 AM
Gshroom's Avatar
hey tweger, how much beer would you charge for opening a headlight then closing it?
Old Sep 5, 2011 | 10:17 PM
Franky's Avatar
Originally Posted by Texasscout
Well done! I don't know if it's possible, but as you said, LEDs are directional, would there have been a way to drill the holes so they all face toward the front? Some of them are pointing almost straight up. What we call down here, "Coon Huntin'"
A quick fix for the directional led beams is to use a fine grit sandpaper on the bulbs to give them a frosted look.
Old Nov 2, 2011 | 08:13 PM
zx14kawboi's Avatar
why not wire them in parrallel
Old Dec 12, 2011 | 06:37 PM
  #30
issues's Avatar
nice write up... looking forward to tryin this
