Pics of my Wilwood BBK installation
Old Jul 7, 2007 | 04:36 AM
  #46
GreenGoblin's Avatar
The goblin resurrection
ya that looks great
Old Jul 17, 2007 | 03:36 PM
  #47
cato's Avatar
SouthernComfort Moderator
It has been a year since I installed the 6 piston Wilwood BBK. When I bought the kit, Dave at ArizonaZCar told me to turn the rotors "after awhile". Well, I did not see why until a couple of weeks ago. The brake pedal started to give a slight shake on stops, making the braking feel like cr*p. So I took my G down to Firestone and asked to have the front rotors turned, asking for only a slight trim on the rotors. They turned the trotors, said there was tons of meat left on them. They also said the front pads look to be worn about 5%! After the trim, the car stops like it is supposed to! Still very happy with the AZC BBK.
Old Jul 17, 2007 | 09:27 PM
  #48
Endless Shock's Avatar
After a year you have only used 5% (+/-)... Wow... How many miles do you drive a month? Are you are late braker or a brake rider? How much did it cost to have your rotors turned?
Old Jul 18, 2007 | 07:08 AM
  #49
cato's Avatar
I'm not hard on brakes. Take what the guy said with a grain of salt, I did't see the pads myself. I have 96,000 miles on my G35 sedan. I do drive it! I have put more than 13,000 miles on her since I did the install. So It seems like the Wilwoods are lasting like I expected them to. 10,000 miles on the OEM crap would call for new pads and rotor turning as well. I had the break fluid flushed and the total bill came to $190. I think they charged $90 to turn the rotors.
Old Nov 16, 2007 | 04:10 PM
  #50
SoCalTed's Avatar
thanks for the update. I think I'm gonna be ordering the FastBrakes Wilwood package. What wheel and tires size you running with the 3mm spacer?
{edit} - duh.. I read your sig. nvm
-Ted
Old May 21, 2008 | 12:52 PM
  #51
cato's Avatar
Update: Approaching two years of having the Wilwoods. My brakes started squealing a few months ago. I figured it must be the rears since I had the brakes inspected recently and the fronts were reported to be 5 mm. Like a fool, I just ordered a new set of rear pads and had my local guy replace them. He gave me back the originals, Stillen metal matrix pads. They were like new! OK, so I begin to suspect the fronts need replacing. NOT! I just got a new set of Michelin Pilot Sport A/S from Discount tire. While they had the wheels off, I examined the Willwoods. Gahhhhh, they look like new!
So the truth is, the Willwoods do squeal a bit, but they last and stop on a dime.
I would have spent at least another $1000 by now on replacement OEM pads and rotors. I do feel vindicated!
Old Jun 14, 2008 | 02:37 PM
  #52
accordfreak's Avatar
do you remember if the rotors are much lighter than stock or about the same?
Old Aug 26, 2008 | 01:52 PM
  #53
cato's Avatar
Holy Crap! It has been another year without needing a brake job! I'm at 108,500 miles now and the brakes are still good. Incredible!
Old Jun 16, 2010 | 02:49 PM
  #54
surma884's Avatar
Cato,
It's about 2 years since you last post on this thread. How are the Wilwood rotors and pads?
Thanks
Old Aug 23, 2010 | 02:08 PM
  #55
G35 Drummer's Avatar
Ever tried to replace the pad your self? if yes,
how do you compress the pistons?
Old Aug 25, 2010 | 04:49 PM
  #56
neight's Avatar
drummer: make sure you open ur brake fluid reservoir (but keep cap on so dirt doesnt get in) then push hard and steadily and they should compress slowly- be sure to hold the opposite side while doing this so it doesnt come out further.
Old Jul 1, 2011 | 01:59 AM
  #57
indiandrives1's Avatar
Its really very complicated to do....
Old Jul 1, 2011 | 09:11 PM
  #58
urban's Avatar
I have the Wilwoods since Feb 2008 and I just changed my fronts a month ago....these things last forever and the rears are still have half life in them.
Car just completed 150,000 miles
Old Jul 6, 2011 | 02:10 PM
  #59
surma884's Avatar
Is the braking still as good as when the pads were new?
Old Jul 6, 2011 | 02:17 PM
  #60
urban's Avatar
Stops on a dime and I need it with the power I am pushing
