DIY: rolling your own fenders.
Old Jun 24, 2007 | 01:03 PM
  #46
Down_Shift's Avatar
The rubberized paint sealant is black (for the black G's hehe)
If it's visible, you can also seal it, then sand it down and touch it up with some color matched paint! I'm so addicted to this 3M stuff right now haha
Old Jul 24, 2007 | 10:49 PM
  #47
foreignsoda's Avatar
geez.
what is your guys' secrets to getting it so tight?
i can't for the life of me get it parallel to the fender line.
Old Jul 24, 2007 | 11:31 PM
  #48
deviljon's Avatar
i think you have to do it many times while just adjusting the angle little by little each time to get the fender folded. when you try to roll it too much it doesn't come out right.
Old Jul 25, 2007 | 12:30 AM
  #49
spooze's Avatar
does applying too much heat mess anything up. like 5 mins or a lil more. i just dont want any paint cracks.
Old Jul 25, 2007 | 02:09 AM
  #50
accordfreak's Avatar
foreign, you roll your fender until it slowly folds in. You're supposed to make several passes. It actually easier with a metal pipe wrapped in several layers of tape.. or you could tape the fender itself with several layers.
spooze- imagine your car sitting out in 100 degree weather. The surface gets pretty damn hot, hot enough to not be able to leave your hand on. Hotter than my hair dryer could get it for sure.
Old Jul 25, 2007 | 02:45 AM
  #51
nikkaitsme's Avatar
nice write up..mite be doing this later (if needed) when i get my rims
Old Jul 25, 2007 | 04:34 PM
  #52
spooze's Avatar
one more thing. people say that rolling fenders will make them weak and warp the fenders. is that true?
Old Jul 25, 2007 | 07:12 PM
  #53
V35 Skyline GT's Avatar
6MT Coupe
I've heard it can make weaker too, but no warping happened on mine.
It's better than cutting the inner fender lip imo that I've heard ppl do instead of rolling.
Old Jul 25, 2007 | 07:44 PM
  #54
redlude97's Avatar
Cutting the fender can make it weaker, rolling the fender doesn't noticeably weaken the fender at all. You aren't removing anything, just bending it.
Old Jul 27, 2007 | 04:04 PM
  #55
s2k_g35's Avatar
Great idea. I'll try it this weekend.
Old Jul 27, 2007 | 06:24 PM
  #56
n1cK's Avatar
G35 6MT
if you don't have metal pipe hanging around or don't want to buy it, use a D cell MagLight!
Old Aug 24, 2007 | 02:43 AM
  #57
spooze's Avatar
i think i might try a baseball bat with some duct tape.
Old Aug 24, 2007 | 10:54 AM
  #58
sevret.t's Avatar
JDM Option Video has a DIY Fender Roll... Check it out
Old Jan 11, 2008 | 09:15 PM
  #59
RealMFG's Avatar
Just finished rolling my rear fenders. Haven't driven it yet so I'm not sure if it'll still rub (stock suspension w/ 285 tires in the rear). I'm not sure how some of you got the clearance you did, mine only folded about 3/4 of the way. I also encountered paint chipping. I used a metal bar wrapped in some duct tape, but the fender cut right through the tape (which in turn caused some of the paint to chip with metal/metal contact), so i switched to masking tape and it worked a lot better. Hopefully I don't have any rubbing issues now and after i put on some coils.
Old Jan 13, 2008 | 06:38 AM
  #60
Pedrog35's Avatar
i just use a baseball bat...works great...
