Factory Alignment Specifications / Specs
Old Feb 15, 2008 | 09:15 PM
bigc's Avatar
Wings Nation
I've noticed a lot of threads asking for the factory recommended alignment specifications for G35s. To my knowledge, we don't have a thread which lists these specs and most responses say just go to an alignment shop. Hopefully this thread can become the one-stop-shop for finding the factory alignment specs.
Below are direct links to the service manual alignment specs Redlude notes below:
Coupe
2003
2004
2005
2006
2007 (doesn't always work )
2008
Sedan
2003
2004
2004.5
2005
2006
2007
Old Feb 15, 2008 | 09:27 PM
redlude97's Avatar
You can find all the factory specs here
https://g35driver.com/forums/showthr...93#post2668693
Old Feb 15, 2008 | 09:30 PM
bigc's Avatar
Wings Nation
you are the man
Old Feb 16, 2008 | 12:41 PM
Q45tech's Avatar
Be sure to set at NOMINAL [EXACT middle of range] for each parameter "in warranty spec" is worthless if ideal tire life is desired!
Old Feb 23, 2008 | 02:48 PM
bigc's Avatar
Wings Nation
the first post now includes direct links to the factory alignment specs Redlude noted.
Old Feb 23, 2008 | 06:09 PM
citymunky's Avatar
Infiniti forgot to add 19" rims to the 2005 guide.
So my question is, are these the spec to use if you have aftermarket rims and/or
drop?? (Sorry, I'm a total NOOB when it comes to alignments, wheel and offsets.)
I have 19x8.5 F / 19x9.5 R with no drop (yet).
Old May 12, 2009 | 06:49 PM
nyckid's Avatar
thanks a lot for the information guys!
Old Jun 1, 2009 | 10:58 AM
UMBG35's Avatar
A friend of the family is a "Nissan Master Tech" (GTR certified) so I can assume he knows what he's talking about when it comes to Nissan products. He had told me that Nissan Corp had updated the alignment specs on the 350Z to decrease the tire feathering issue (excessive inner wear of the front tires). Is this public information which is updated by shops such as NTB? I bought a 3 year unlimited alignment package and been getting an alignment every 6 months on my 2005 coupe with oem 19s, everything on my car is stock. I run OEM 19s for 3 seasons and oem 17s in the winter. I remember when I got an alignment at the dealership on the Potenzas RE050A, it seems to have worn a lot evenly than other setups (Falken 452, Toyo T1Rs) that I have had aligned at National Tire & Battery. Any inputs? I don't mind going to the dealership and paying $90 IF they are aligning to updated specs. Any information would be helpful. I called the dealer and the person that I talked to said he doesn't know and they just go by what the computer states :/
Old Jun 1, 2009 | 10:21 PM
bigc's Avatar
Wings Nation
hmm, that's a good question. bump - hopefully someone knows!
Old Jun 2, 2009 | 07:10 PM
Q45tech's Avatar
Factory specs are the amount of misalignment* necessary with OEM as built suspension to maximize MPG at 55 mph. When every you lower or redesign the suspension [wheels, tires, springs, etc] you must create a new set of YOUR Alignment specs.
Most don't understand this and copy oem specs because they do not have engineering expertise or test equipment necessary.
* misalignment sitting still so that it is optimum on highway at speed when the bushings are compressed by forward speed. Tires are forced rearward and straight [toe] by rotation forces.
Old Jun 2, 2009 | 07:12 PM
bigc's Avatar
Wings Nation
^ do you know if the OEM alignment/misalignment specs have been updated?
Old Jun 2, 2009 | 07:21 PM
G35Papa's Avatar
Great info
Old Mar 26, 2010 | 11:08 PM
NFSP G35's Avatar
? = 2B || !2B
Hey Chris, you wanna add the specs for the Z?
Someone recently said they put Z springs on their sedan, and it wouldn't quiiiiiite go back into spec for the SEDAN but it did go into spec for the 350Z.
Old Mar 26, 2010 | 11:38 PM
bigc's Avatar
Wings Nation
i'll dig around online to see if i can find all the manuals hosted somewhere, but i can't make any promises.
as for the guy with the z springs, i think he should be using the specs for a G regardless. my guess is he'll need camber kits (front & rear) and toe bolts to get back into factory specs. he'll have to decide for himself whether the expense is worth it.
Old Mar 28, 2010 | 04:18 PM
LiquidREVUP's Avatar
nice find... factory service manual FTW!
