Tokico D-Spec setting for track day?
Old May 21, 2006 | 10:07 PM
willthethrill's Avatar
I spent some time searching and did not find anything specifically pertaining to the setting of the D-spec shocks for "Track" use. I have the 350Z D-Specs(4f 5r for daily driving) and 350Z H-Techs installed on my coupe. Next month i will be going to do a road course event and am unsure what I should start my settings out at. Any advice would be appreciated.
Thanks
Old May 21, 2006 | 10:14 PM
kenchan's Avatar
you may or may not want to change the setting. do you have swaybars?
that might net you better turnability than just stiffing up your dampers.
stiffing up the sus does not equal better handling.
Old May 22, 2006 | 12:44 AM
No the sways are still stock. Thanks appreciate the info.
Old May 22, 2006 | 12:49 AM
wa2good's Avatar
Thanks
IMO, In your situation, you would probably get the best results with your D-Spec's at full stiff, all the way around.
Old May 22, 2006 | 12:48 PM
obender66's Avatar
Get sway bars while you still got time. Stiff shocks will not help with body roll.
Start with 3-3.5 at the track and work them up in 1/4 turns.
I ended at 1.5/2, but I have different springs and track layout will matter too.
Old May 22, 2006 | 08:13 PM
geeitup's Avatar
Its been discussed here before, but most have said to stiffen up the front a couple turns more than the rear to limit body pitching due to weight transfer under braking.
Old May 23, 2006 | 09:39 AM
Really? I wasn't able to find any previous discussion on the subject...then again i seem to suck at the searching If you happen to find any of those discussions please point them out to me.
Thanks for the advice I will start out with the front stiffer than the rear and see how that feels.
Thanks again everyone.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
joel extreme
Jul 27, 2015 11:59 PM
joel extreme
Jul 23, 2015 04:13 AM
mushu
Jul 15, 2015 03:55 PM
