Diff. between Gold and Red Stillen sways?
Old May 31, 2006 | 05:26 PM
kenchan's Avatar
>when i remove those front sway bushings should i lube them again or just throw them on.
Yep, lube them inside out. i use white lithium grease.
>Also im using rhino ramps to lift the front should be fine correct?
yep.
>Another question: For the rear (and front) should i buy endlink bushings or will it be fine without (i dont want any creaking).
just use stock.
>Rear i also will be using rhino ramps since i doubt it is necessary -correct me if im wrong- to remove the rear passenger wheel to remove the sway bar.
just use the ramps. no need to remove the wheels front or rear to do swaybars.
Old May 31, 2006 | 05:42 PM
dream_G35's Avatar
thanks
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Blue Dream
Dec 5, 2015 10:56 AM
NyCrAzY
Oct 1, 2015 09:19 AM
