Dont buy Rotora rotors for Brembo if.
Old May 30, 2006 | 03:57 PM
Kidcane's Avatar
You plan on putting different rims on your G. I had my front rotors replaced with Rotora rotors and I just bought a new set of Maya STM's and when I go to put them on, the do not fit right because the replacement rotors are too wide. I even tried a 5mm spacer and still does not work so I went to a 7mm spacer and then I only get 4 turns on the lugs which is not enough for me when the factory get 10 turns. Now I have to buy new rotors for the front when I dont even need them yet. SUCKS!!!!
Old May 30, 2006 | 04:11 PM
Glex25's Avatar
Administrator
why dont you try getting longer studs for the rotors.
If that is the reason why you don't have enough threads to tighten up your wheels.
Old May 30, 2006 | 04:41 PM
Kidcane's Avatar
^^ Brilliant!! I am retarded for not thinking of that. Any idea if that is fairly easy or is it a complicated procedure?
Old May 30, 2006 | 04:53 PM
superchargedg's Avatar
you could also check into useing kic,s spacers.they bolt on to the original studs and have different thickness,s and have there own studs to bolt the wheel to.
Old May 30, 2006 | 05:15 PM
Blackbird V35's Avatar
I don't understand what you mean by the rotors are "too wide"
i was looking into these rotors and i would like to know what you mean
Old May 30, 2006 | 06:05 PM
Glex25's Avatar
Administrator
Real simple.
Just take the rotors off the car and hammer the stud out.
Bring the stud to the auto part store and i dont mean autozone.
Tell them you need a longer stud with same thread pattern and your set.
Old May 30, 2006 | 09:37 PM
GolfHawk's Avatar
Is this only a problem with the Brembo replacements?
I ask because I am getting Maya wheels and I am also getting the Rotora replacement rotors. Since my car will be an 06 5AT, should I be ok?
Old May 31, 2006 | 12:13 AM
dubs's Avatar
I have a rotora BBK & maya 20" RT5's with no clearence issues.
Old May 31, 2006 | 01:19 AM
Originally Posted by Glex25
Real simple.
you need more than thread pitch, you need shoulder width and knurl as well
Old May 31, 2006 | 01:24 AM
Glex25's Avatar
Administrator
Thats why i said to take one out and take it to the store.
Got to cover all bases
Old May 31, 2006 | 12:05 PM
shunra's Avatar
Or just order the NISMO long wheel studs online - that is what i did.
http://www.courtesyparts.com/nismo/bolts/index.html
Old May 31, 2006 | 07:43 PM
Kidcane's Avatar
Ok finding the studs is not a problem, I got them. Now I am told I will have to remove the hub too to get the studs? Is this correct, or do the rotors come right off and then you can remove the studs?
Old May 31, 2006 | 07:56 PM
shunra's Avatar
I can't answer as to the back ones b/c I only changed out my front ones. But the front rotors came off on their own as soon as I removed the brake calipers. After that getting at the studs was easy.
Old May 31, 2006 | 08:17 PM
Kidcane's Avatar
^^ About how long did that take you?
Old Jun 1, 2006 | 07:31 PM
Kidcane's Avatar
Nevermind, I got it done. Cost me another $50. Thanks.
