sway bar experts.
Old May 31, 2006 | 02:49 AM
Klubbheads's Avatar
sway bar experts.
Ok i installed my hotchkis sways(the rear only) a month ago on medium setting. The car felt the same as it was before which was very balanced a lot of grip and bit of overstear, which i like, when u take it to the limit. Keep in mind i already had the z shocks and tein-s combo. Ok i installed the front one about 2 days ago and the handling changed completely. I changed the rear to the stiffest setting and the front to the medium. When i take it to the limit the front tires dont grip too well. It basically understeers when i push it. It feels like all the cars weight is on front tires but at the same time it understeers.
Question: Should i go med/med instead of stiff/med to see what happends?
I thought when u stiffen the rear one it should oversteer more, no?
Old May 31, 2006 | 02:53 AM
GLuXuRy's Avatar
If you like oversteer... i here to have stiff in the rear and med in front (atleast thats what Q45tech suggest) for oversteer. But thats odd that you already have that setup and you dont get any oversteer. HMMMM
Old May 31, 2006 | 02:56 AM
Klubbheads's Avatar
Well i get oversteer when i pound on the throttle in the middle of the corner going 40MPH on second gear. But the car is not as balanced as it used to be with just one rear swaybar with medium setting. The initial response when taking a corner is a lot of grip and no body roll. But again when i push it little bit more the front tires start to make noise and it goes to understeer mode.
Old May 31, 2006 | 03:01 AM
norcal_chan96's Avatar
I had the same problem with understeering... I have the STillen sway's and i had them set at MED/MEd... It was understeering pretty bad when i took turns hard... I changed the fronts to the soft setting... And it allowed a little bit more for body roll to carry through the turn... I like how it is now... But i also have a Strut tower Brace...
Old May 31, 2006 | 03:07 AM
Klubbheads's Avatar
So changing the rear to medium will not help? I should go with stiff rear and soft in the front?
Old May 31, 2006 | 05:25 AM
dofu's Avatar
20 Year Member
With an upgrade like sway bars, imo, you really want spring rates to match. But I have found that bigger sways work much better with a stiffer chassis.
Either way, you're changing a set-up you liked to begin with which imo, is a big mistake already.
You might want to try putting the front sway bar to it's softest setting... and if you don't like that still, then go back to the stock front sway bar.
Old May 31, 2006 | 05:32 AM
Klubbheads's Avatar
Looks like im gonna try go with sitff/soft and see what happens.
Old May 31, 2006 | 05:39 AM
dofu's Avatar
20 Year Member
You can try adding tie bars...
Old May 31, 2006 | 07:59 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
You can also go a half step.
eg. on the same bar (rear) use stiff on one side & medium on the other = med/stf
Old May 31, 2006 | 09:06 AM
kenchan's Avatar
max oversteer bias: soft front/firm rear
max understeer bias: firm front/soft rear
Old May 31, 2006 | 02:02 PM
Klubbheads's Avatar
If i do that will it be about 119% stiffer than stock instead of 146%. Also there won't be any issues with direction changing right?
Old May 31, 2006 | 05:20 PM
kenchan's Avatar
you'll first need adjustable endlinks to do that and no, there is no directionality as to which side gets to be hooked up in the stiffer or
softer hole setting.
Old May 31, 2006 | 05:26 PM
Jeff92se's Avatar
Red Card Crew
I'm on stock non-sport suspension. But on Hotchis and oem 19s. I intially ran soft/med. Handling was better but the front still wanted to dive a bit. So while I was changing my oil, I put my front bar on med. So at med/med, it's great. Now I haven't seriously pushed the car yet though. I guess I should take some fun runs w/o the VDC huh? But if you want to dial out some oversteer, try med/med and see how you like it. Hell, it's easy enough
Old May 31, 2006 | 07:44 PM
Klubbheads's Avatar
Just came back from the local canyons. I changed my mind about changing the settings. The car changes directions very fast and flat. Yes at the limit it understeers a bit, but it is very predictable. The reason that the car is so twitchy at times is because i have my stock 17s on with gooyear eagle f1s. When i put back my 19s I will then think about touching the sways.
Thnx for the suggestions.
Old May 31, 2006 | 08:43 PM
obender66's Avatar
Try to change your driving style. When you pound on the throttle in the middle of the corner you unload front tires and they start to slip. Try to "gently apply the throttle". By the way you describe how car behaves at the corner entry your set up is fine.
