installed kinitex camber kit PROBLEMS
Old Jun 9, 2006 | 05:10 PM
phenom1011's Avatar
Exclamation installed kinitex camber kit PROBLEMS
The upper joint or whatever is hitting the upper part of the fender. There is a horrible banging sound going over bumps. Everything was fine before. The shop said that is the only way it can go in. The back is fine.
Old Jun 9, 2006 | 06:43 PM
G35pm's Avatar
I assume you're referring to the front camber arm. Did you get an alignment already? Maybe the shop that installed it set it at too much positive camber.
Or maybe they put the arms on the wrong side. e.g. left on right, vice versa
Maybe you should check your parts too. They could have give your two right arms or two left. I ordered 350evo arms before and got two left arms on accident.
Old Jun 9, 2006 | 08:22 PM
phenom1011's Avatar
Yes the camber arm is hitting a protruding part of the wheel well on both sides the guy at the shop said the alignment's dead on. Is it clearly marked left and right? Everyone goes to this guy I figured I wouldn't have a problem. Thanks for your suggestions. I am hoping someone else had this problem and its an easy fix.
Old Jun 9, 2006 | 09:48 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
There is a limit to how far out you can adjust them.
FWIW...
1. You need to trim the plastic wheel liner a bit.
2. You can also work the upper cup steel out a bit (hammer out) to gain more clearance.
Old Jun 9, 2006 | 09:55 PM
phenom1011's Avatar
So its normal... thanks a lot
Old Jun 9, 2006 | 10:16 PM
kenchan's Avatar
not normal, but some have accepted the sideeffect.
Old Jun 9, 2006 | 10:47 PM
phenom1011's Avatar
I ment that everyone that installs the kit will run into this. If not then I would have a bigger problem.
I want to grind the area down down does anyone know if there are hidden wires I need to look out for?
Old Jun 10, 2006 | 02:40 AM
kenchan's Avatar
^^ pull the liner down b4 you start dremeling.
Old Jun 10, 2006 | 09:06 AM
phenom1011's Avatar
I did, the part it was hitting is already bent in about an inch.^
Old Jun 10, 2006 | 01:04 PM
redlude97's Avatar
its a pretty common problem with camber kits and lowered cars, many people had the same problems with the front control arms on the prelude, it would actually break through the metal leaving a hole in the engine compartment
Old Jun 10, 2006 | 09:41 PM
phenom1011's Avatar
I tried grinding it down a little, still hitting. How much do I take off
Old Jun 10, 2006 | 10:17 PM
Chico's Avatar
have you called Kinetix yet? On their website and the times I have spoken to them, it was never stated that the part or the car has to be modified to fit properly. Personally, I wouldn't keep it on the car if it doesn't fit properly.
Old Jun 11, 2006 | 12:08 AM
kenchan's Avatar
i had a Gen5 lude (long time ago) and was 2.2"+ lowered and no
issues... TEIN HA's with pillow mounts. i had a WRX with similar
setup (a while ago) running HA's with pillowmounts as well... no
clearance issues.
hitting the liner or clearance issues has never been a common problem
for me....either the part was made without much consideration to the car
or just not done right.
Old Jun 11, 2006 | 05:48 AM
phenom1011's Avatar
The dumb f***s put them in upside down! Someone here posted pics and I noticed the grease fittings where faced up. mine are down.
Thanks for all your suggestions
Old Jun 11, 2006 | 06:10 AM
G35pm's Avatar
Knew it was some kind of install error. Glad you found the problem.
