Suspension Help
Old Jun 12, 2006 | 11:02 AM
barrios35's Avatar
Suspension Help
I am not sure if my front shock is blown? How do I check? At times I hear a thump sound...
Old Jun 12, 2006 | 01:10 PM
dTor's Avatar
Is your vehicle lowered? If so, did you use the stock or factory shocks? Did you cut/replace the factory bump stops?
Oh yeah, if you push down on your car where the shock in question is and the car keeps bouncing, you probably have a bad shock.
Old Jun 12, 2006 | 01:13 PM
barrios35's Avatar
2003 Sedan All stock.
Old Jun 12, 2006 | 01:32 PM
kenchan's Avatar
check for leaks
Old Jun 13, 2006 | 12:04 PM
DannoG35's Avatar
When do you hear the thump? I had a thump from one of my sway bar bushings before. I have stillen sways though with poly bushings and had to switch back to stock bushings.
Dan
www.***********************
Old Jun 13, 2006 | 04:46 PM
barrios35's Avatar
When I go over bumps... Some of the bumps are not even that big.
If it is blown, do I have to replace all 4? Anyone know how much stocks run or is better just get aftermarket shocks?
Old Jun 14, 2006 | 10:57 AM
barrios35's Avatar
Ok, I pushed up and down on the car. I heard nothing??? Any ideas?
Old Jun 14, 2006 | 11:10 AM
SilverII's Avatar
When I go over bumps I hear a little Psssssttt on the front and nothing on the back.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
