Tein S-tech install time?
Old Jun 13, 2006 | 12:13 PM
DannoG35's Avatar
I am planning to install my S-techs and was wondering if anyone knows what the install time is. I have heard the there are shops that do them in about an hour. Is there anything I need to know about the install. I have searched for a DIY but had no luck. If anyone has a link to a DIY that would be great. Thanks
Dan
www.AggressiveOverlays.com
Old Jun 13, 2006 | 12:28 PM
kenchan's Avatar
i would say 2 hrs tops.
Old Jun 13, 2006 | 12:50 PM
DannoG35's Avatar
Ok so I have a shop to do this in but I can get a spring compressor rented from Auto Zone right?
Dan
Old Jun 13, 2006 | 01:05 PM
DRAGMODE's Avatar
or you can buy a pair from harbor freight ($15)...either way they are really cheap. The front may take an hour and 30 min. for the rear. I took a little longer on mine because I installed control arms (front & rear) same time as springs.
Old Jun 13, 2006 | 01:16 PM
Blackbird V35's Avatar
bout an hour 20 if you have good air tools
Old Jun 13, 2006 | 02:55 PM
DannoG35's Avatar
Auto Zone only requires $50 deposit and you get it back when you return it. Thanks guys.
Old Jun 13, 2006 | 03:02 PM
DannoG35's Avatar
I have got plenty of air tools so I am all set there.
Old Jun 13, 2006 | 03:23 PM
afr0puff's Avatar
Supa Dupa Moderator
http://g-owners.com/article_read.asp?id=25
The struts only go in one way. I learned that the hard way. YOu think that all sides are equal, but it's off by 1mm or so and enough to cause hours of frustration if you don't know. To prevent that from happening, the outer-most strut bolt is supposed to be "marked" somehow. My mark had worn out. So be sure to put a drop of touch-up paint or nail polish on it before you start.
Old Jun 13, 2006 | 03:42 PM
DannoG35's Avatar
Thanks for the link to the DIY ^. I printed that so I can use it as a reference.
Old Jun 13, 2006 | 03:57 PM
sen_jen's Avatar
Meatshake Enterprise
i did 2 coupes and 1 sedan in 1 hour, 40 minutes with no air tools. i just popped 1 ephedrine pill, and ratcheted away like a fiend on the spring compressors. the stock suspension bolts were kinda frozen too, so i had to penetrate them with bolt loose. if i didn't have that problem, i'd have been done is about 1 hour 10 - 1 hour 15 minutes.
Old Jun 13, 2006 | 04:07 PM
Espresso's Avatar
^^You're kidding right? If not, you're a beast!
Old Jun 13, 2006 | 04:15 PM
aam6906's Avatar
have fun doing your alignment
Old Jun 13, 2006 | 09:44 PM
aleok's Avatar
i'm about to install mine too. please let us know how everything went. reading the DIY scared me when it said "BE CAREFUL. This is where the spring can shoot out!"
Old Jun 14, 2006 | 01:16 AM
DannoG35's Avatar
A little sarcastic there........Its obvious that you need to take your car in for an allignment.
Old Jun 14, 2006 | 01:17 AM
DannoG35's Avatar
Thats why you have the spring compressors to save your ***.
