"Sport Tuned Suspension"/ Eibach Lowering Springs
Old Jun 15, 2006 | 11:51 PM
SURFJ9009's Avatar
Question "Sport Tuned Suspension"/ Eibach Lowering Springs
Here is one I haven't seen discussed much (I probably missed it)
I am getting a 2006 6MT Coupe in about a month. This one comes with the "sport tuned suspension"
How much of the "sport tune" do you guys thing I will lose if I install Eibach's Pro springs?
I want to lower it about an inch to close the gap in the fenderwell. Gonna install 20's too. Just curious what, if any performance I may lose.
Old Jun 16, 2006 | 12:09 AM
gary c's Avatar
Eibachs...................
Why would you think that you'd lose performance
by installing lowering springs? After you buy the
car and after you have the springs installed make
sure your alignment is within specs. The only way
you'll lose hp is if you install super heavy 20s!
Keep it LIGHT!!!
Old Jun 16, 2006 | 12:23 AM
SURFJ9009's Avatar
I am probably gonna install ADR Sterlings.
20x8.5 in the front, 20x9.5 in the rear. With maybe 30 or 35 series Toyos. Not to sure on tire series yet either. Suggestions are welcome here.
Does anybody know how much more these weigh than the stock 19's.
Old Jun 16, 2006 | 02:58 AM
Klubbheads's Avatar
From what they look like, u are going to lose about 0.3-0.4 seconds in a 1/4 mile. Stock 19s are very light for being 19s.
Old Jun 16, 2006 | 03:02 AM
SURFJ9009's Avatar
Ok, how about compared to Axis Mod 20's?
Old Jun 16, 2006 | 03:28 AM
Klubbheads's Avatar
I think it is a better choice, eventhough u are going to lose some performance no matter what kind of 20s u put. But i think Axis Mods look better than the pic that u posted.
Old Jun 16, 2006 | 03:33 AM
SURFJ9009's Avatar
I think your right, saw a pic of a BO coupe with the Axis mods, and for the price difference, which aint chit, i think i will probably get the mods. still doing my homework with the search engine.
so, back to my ?
axis mods and eibach springs on a 6mt "sport tuned suspension", what do you think?
Old Jun 16, 2006 | 03:47 AM
Klubbheads's Avatar
worst case u will roll ur fenders but as far as looks it will look very good.
Old Jun 16, 2006 | 08:27 AM
jclit's Avatar
Can you make the font a bit bigger?
Old Jun 16, 2006 | 08:32 AM
SURFJ9009's Avatar
SURE, ANYTHING FOR YOU.
SMARTAZZ.
Old Jun 17, 2006 | 03:08 PM
Gsedan35's Avatar
Your oem starting point
314/427 on linear springs
What you thinking about
Eibach G35 Coupe progressive springs 1.1”/1” drop
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
Weight transfer issues will be effected, as in brake dive and squat when rolling on and off the throttle. Turn in will also be effected unless you equip with aftermarket sway bars. And even then you'll still have the issue of being on two different spring rates side to side while cornering. Overall compromises on performance I wouldn't stand for.
You can ditch the perfomrnace compromise by going with 350Z RSR springs and get the same drop on linear springs. Since you have the 05/06 coupe sport suspension shocks, no reason to believe that you don't have enough shock dampning. Though as alway's Tokico D-specs would still be a worthwhile upgrade, because they are simply better.
RSR 350Z linear springs 1.1"/1.1" on G35 coupe
Spring rates in LBS 345/417
Old Jun 17, 2006 | 07:03 PM
SURFJ9009's Avatar
Question
So.....I think what your saying is that if I go with the RSR 350Z springs I will get a 1" drop, but still have performance close to stock with my current shocks? (even better if I go with the Tokico shocks, right?) But the cornering
should be better because the srping rates will be closer to each other in the sides, right?
Would you say that I should go with G35 Tokico's or 350z Tokicos if I get the RSR 350z springs?
Thanks in advance for helping me sort through the confusion.
Old Jun 18, 2006 | 12:25 AM
SURFJ9009's Avatar
bump
Old Jun 18, 2006 | 11:16 AM
Gsedan35's Avatar
I just replied to your pm, but I did want to answer the D-spec question above. If you get Tokico D-specs go with the one's ment for the 350Z. Also keep in mind that your oem suspension does have a value here in the market place, selling the shocks/springs would help recoupe your investment in aftermarket shocks.
Old Jun 18, 2006 | 07:25 PM
SURFJ9009's Avatar
Gotcha! I am gonna sell my stock 19's and tires to help pay for my new wheel/tire combo.
Will be doing the same here too!!
jsimonk
Dec 22, 2023 03:49 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
nosam1g
Aug 22, 2015 11:58 PM
mostestG35
13
Aug 15, 2015 05:56 PM
