adjusting coilover ride height
Originally Posted by kenchan
also you need to get adjustable endlinks on your swaybars if you're going
to do it correctly.
to do it correctly.
Am I doing something wrong or are adjustable end links necessary?
Pic of my problem (It will not go in any of the sway bar holes):
maybe you set the dampner too low? or try removing the bottom of the coilover from the lower arm...then put the endlink in, and then put a jack under the arm to get it to compress slightly to slip the bottom of the coilover in there.
workin' kind of late/early, aren't ya?
The way I was told to adjust the height was to adjust the damper length. I could make the damper longer to make it fit the arm, but I would be raising the car. I thought about putting the endlink in first, but it looks like the pressure needed to jack up the lower arm in place for me to attach the shock would break the endlink or mess up the sway in some way.
It's weird because I've never heard of anyone having this problem.
Ok, is there a way to change the front height without taking the coilovers out? My coilovers are setup like Tein Flex, so I have 2 locking nuts for the spring perch and one for the damper. If I loosen the damper nut, how do I change the height with everything in place?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
master111
Sep 25, 2015 08:32 PM
