Massive understeer.HELP?
Old Jun 30, 2006 | 04:24 PM
MikeStarrG35's Avatar
Obsessive Owner
Hey guys, as the title reads my car is severly understeering. I have Stillen Sway bars installed and set to med/med. I was wondering what I should adjust them too in order to fix the understeer. Should i go med/soft front and med/hard rear, or shud i go med front n hard rear?? Any suggestions?
Thanks
Old Jun 30, 2006 | 04:29 PM
Jeff92se's Avatar
Red Card Crew
Front soft Rear med. Report back. You sure it's understeer? I running med/med on my Hotchkis (03 sedan) and I don't get understeer at all. Certianly not massive
Old Jun 30, 2006 | 04:36 PM
speeddreamz's Avatar
well if the mods are current below, your car will understeer cuz its got no suspension, or you're entering the turn wrong.
Old Jun 30, 2006 | 04:50 PM
glennp_1999's Avatar
Soft front and med rear or med front and stiff rear. It shouldn't matter if you have stock suspension. How's your tire still have a good amount of thread on it? Tire pressure correct?
Old Jun 30, 2006 | 04:52 PM
jclit's Avatar
I would go with med front, hard rear
Old Jun 30, 2006 | 05:54 PM
Sukairain's Avatar
You can cure mild to moderate understeering with sway bars, tires and suspension mods. However, the only thing that will cure SEVERE understeer in the G is driving school.
Old Jun 30, 2006 | 06:21 PM
Obsessive Owner
I am currently running stock suspension. I forgot to add to my original post that I just put on 245/35/19 275/30/19 Toyo T1R that have pretty much 100% tread. They have had time ot break in.
Old Jun 30, 2006 | 08:02 PM
wa2good's Avatar
Thanks
So many factors can contribute to under steer on a G, like tire width staggers, suspension settings, etc.
As for the sways, try med. to med/soft front and all the way stiff on the rear, (a very common setting for our cars).
Old Jun 30, 2006 | 08:42 PM
Klubbheads's Avatar
+1, try medium in the rear and soft on the front, if it doesn't help, try stiff rear and medium front. But on a stock suspension med/soft should do it.
Old Jul 1, 2006 | 12:00 PM
Gsedan35's Avatar
Thanks
Is this your experience with a wide range of cornering speeds and radius's? I would expect more of what you talking about to turn up in really tight low speed corners where push is going to be more of a issue. What tires are you on and what pressure's are you using?
Old Jul 2, 2006 | 09:30 PM
Obsessive Owner
Yes, it is much more apparent at really tight low speed turns. I am running 245/35/19 front and 275/30/19 rear Toyo T1R on stock 19's.
Old Jul 2, 2006 | 10:09 PM
kenchan's Avatar
i would use soft (f) hard (r) and use stock size tires on stock wheels.
carid
Aug 22, 2016 01:34 AM
Frostbite91
Aug 2, 2015 04:59 PM
